Lazy Antenna
Old Apr 25, 2008 | 07:30 AM
ps374's Avatar
ps374
Default Lazy Antenna
I noticed lately when i turn off my radio on my 84 the Antenna goes down all but about 5 inches of it. After about a minute or so the Antenna then goes into full down position. Should I expect to be replacing my Antenna soon or is there a way to lubricate it?
Old Apr 25, 2008 | 07:40 AM
runner140*'s Avatar
runner140*
To lube the antenna might be a quick, short term fix but usually the fix is an antenna replacement. They come with a plastic ribbon with teeth and these "teeth" after some years, break off.
Do a search in the above search icon for a step by step direction on the replacement. Its an easy and cheap fix.
Old Apr 25, 2008 | 08:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The early C4 antenna used a round nylon rod with a hooked end. When the rod breaks, your antenna will run forever. Try a little lube, if that doesn't work, maybe a good cleaning and lube of the internals will do the job.
http://members.shaw.ca/dankai/Power%20Antenna.pdf
To Lazy Antenna
