Need some assistance...
My question is however, the two brake lights on the passengers side are not lighting? I can't imagine that both lights are bad at the same time, and I only get parking lights if i turn them on.....sounds like a bad ground to me...any ideas?
Also don't have any backup lights; a while back a fellow worker of mine told me that my backup lights were on when going down the road after leaving work. Would a ground do that too?
I hate wiring.
Any help in tracking it down would be appreciated.
Thanks.
The backup lamps could be a bad switch based on the symptoms, or even a fuse.
Don't let the wiring intimidate you, should be able to check it out with a test light.
