carb swap timing
Old Apr 28, 2008 | 10:21 PM
Cruzercat's Avatar
Cruzercat
Default carb swap timing
carb swap guys
what do you set your c4 L98 700r4 timing at ???
i am trying 10 degrees
what works best for you ???
thanks
raf
Old Apr 29, 2008 | 03:02 AM
hexane's Avatar
hexane
Originally Posted by Cruzercat
carb swap guys
thanks
raf
10 degrees is what I have mine on. I could use more timing, but then it will knock after it warms up past 180 degrees. My total spark is fully advanced from about 3000 up to 6500 rpms where I shift. I'm running 36 degrees of total timing.
Old Apr 29, 2008 | 05:03 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I run a total of 38 deg ,I have mine locked out .Just a bit doggie on the take off.
Old Apr 29, 2008 | 08:22 AM
RacerX70CC's Avatar
RacerX70CC
34 degrees total advance...
To carb swap timing
