spaced out man
Old May 4, 2008 | 03:52 AM
supersmoothpunk's Avatar
supersmoothpunk
Default spaced out man
I own an 87 vette and want to put some wheels that fit the later c4. Is it true that this can be done with 0.75" spacers? what size wheels can i go to? 17"? also can anybody recommend a good place to buy the spacers?
Old May 4, 2008 | 09:00 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You would want adapters, not spacers. Yes, 3/4'' is the amount needed to correct the offset. Anything more than 18" wheels, just doesn't seem to look right.
Old May 4, 2008 | 11:27 AM
ZD1's Avatar
ZD1
Source = vette brakes
Old May 4, 2008 | 12:54 PM
staugur's Avatar
staugur
Why mess with adaptors or spacers when there are plenty of aftermarket wheels with the correct 36mm offset that you need for an '87. They are nearly all 17" which to me is the perfect size.Check out AFS,Factory reproductions,OE concepts, OE wheels,Tomzwheels et al.Whatever you decide on DON'T use spacers.
Old May 5, 2008 | 04:41 AM
supersmoothpunk
thanks for your help, i was struggling to find nice wheels but i`ll check out them sites.
To spaced out man
