AC Question
Old May 4, 2008 | 10:22 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by MikeC4
Yes, sounds good....but if you have to:
2. If leaks, fix them and fill it
You will need to draw down the system(ie vacuum down) to remove moisture from the system before you "fill it". Once you open your system to the atmoshere, air and mositure immediatley enter.....When I do R134 work, I duct tape an AC hose to my shop vac and hook it up to the Low side and let it suck for 30 minutes, then do the same on the High side....I have never had any problems with this method...
I am ill equipped to do AC work, I'm taking it to my guy.....thanks for the suggestion.
Such a PIA because of the R12....
Old May 4, 2008 | 10:38 PM
schrade's Avatar
schrade
on/off cycling of the compressor is normal to keep the evaporator from freezing up, however, 3-4 second intervals of cycling is to frequent. This will lead to early clutch failure. My guess is that your oriface tube may be clogged.
Yup.
Old May 4, 2008 | 10:40 PM
schrade's Avatar
schrade
Originally Posted by jsup
Like I said, I don't have the tools or the knowledge to do it, so I will be taking it somewhere.
My concern is the R-12..I know someone in the AC business, hopefully they can help. I have two 1lb cans of R12 on my garage shelf, and a charge kit, hope we can use those.
I'd put the R-12's on ebay, and convert to R134.
Old May 4, 2008 | 10:42 PM
schrade's Avatar
schrade
Fick and GA are right on the money and I apologize for missing this. What you need to do is visually look at all your AC connection points for residue from a leak. Check the rubber hoses as well, as they can also develop pin hole leaks over time. I too have an R12 system in my '93, and this stuff costs more per ounce than gold !! (not really, but it will cost alot, assuming you can find a shop that still deals with R12).
You were right the first time.
If his orifice tube is plugged, it don't make no matter nevermind anywho whatever HOW much freon is recharged into the lines.
So I have three cans, 14oz each
that's well over $100 worth...
Old May 4, 2008 | 11:03 PM
sharp90's Avatar
sharp90
Default ac is painful
As an HVAC tech, imo, R-134a sucks. R-12 is awsome. problem R-12 is regetably "liquid gold" as we call it, and is availble, for a nominal fee. If you know someone in the a/c trade, give him 50 bucks to look at it. they will be able to check the system out, check pressures, switches, superheat, subcooling, general operation. If you ask a tech what superheat or subcooling is, and he answers, "uh, uh, I don't know" don't let him touch your car. or take it to a real auto a/c repair shop. it will be painful either way.
Old May 4, 2008 | 11:09 PM
schrade's Avatar
schrade
As a shade tree hack, I'm in wholehearted agreement.
As a non-BillGates-type, I wouldn't put R-12 (liquid gold) in 20 year old plumbing.
Old May 4, 2008 | 11:19 PM
sharp90's Avatar
sharp90
as I also agree, for the average car owner. converting will mostlikely be the best option, if a leak / low charge is the problem. it could possibly be a pressure switch that may be defective. or half dozen possible problems, it would be best to have a shop look at it. one you know is not going to rip you off. good luck.
Old May 4, 2008 | 11:22 PM
sharp90's Avatar
sharp90
You will need to draw down the system(ie vacuum down) to remove moisture from the system before you "fill it". Once you open your system to the atmoshere, air and mositure immediatley enter.....When I do R134 work, I duct tape an AC hose to my shop vac and hook it up to the Low side and let it suck for 30 minutes, then do the same on the High side....I have never had any problems with this method... I just refuse to pay these rediculous prices to "AC specialists" for work....It 'aint rocket science as they would have you believe....It's simple closed system refridgeration that has been around for decades!!!
shop vacs are NOT vacuum pumps
Old May 5, 2008 | 10:14 AM
jsup's Avatar
jsup
What's involved with that in terms of cost/work?
If I can get the R12 going for this year, that's good enough for me, I can worry about that next year.
Unless I have to replace the compressor, I can't see the conversion being fiscally responsible. The 134A compressor on Rock Auto is $700 vs. $500 for an R12 compressor.
I don't see where a conversion makes sense, plus, I LOVE THE COLDNESS of R12.
Old May 5, 2008 | 12:47 PM
jhammons01's Avatar
jhammons01
yeah, I was going to take issue with that idea as well.
Shop vac=High CFM low base pressure....very very low base pressure
Vacuum pump for A/Cs=very low Cfm and decent base pressure of rough vacuum....10e -2 ish area
jsup, if your system is just low.....2-3 cans is way over kill. Understand it is like filling your tire when you see it down to 25psi....you only need to shoot a bit of air in there to bring it back to 35psi.......same thing for your a/c, you'll need half a can to bring the high side pressure up to spec. You only need 2-3 cans to fill the thing from the starting point of empty....
Old May 5, 2008 | 01:55 PM
jsinga's Avatar
jsinga
I'm with the last poster. You're about 1/2 can low. Just take you're can rig, connect it to the accumulator port and feed in R12 until the compressor stops cycling when you hold the engine to 2000rpm. DONE until next summer!
If your compressor doesn't rattle bad oil is OK.
Oil leak on early C4 is mostly out the compressor front seal. See an oil streak on the bottom of the hood?
Keep R12 in it as long as you can. Then go to one of the mixes that don't require an oil change. I'm with others, R134 is not #1 way to go for a vette.
JS
Old May 5, 2008 | 02:09 PM
MikeC4's Avatar
MikeC4
You guys are right about the shop vac, however, time cures all if you leave even a weak vacumm source on for a VERY long time....which I do....
Old May 5, 2008 | 02:24 PM
  #33
jsup's Avatar
jsup
Cool. that's what I was hoping to hear. Like I said, AC isn't my thing. Losing screws in the cyl is my thing....
Old May 5, 2008 | 04:35 PM
  #34
Da Mail Man's Avatar
Da Mail Man
Thanks everyone.
Cool, I'm going to have it measured.
I have 2 cans of R12 in the garage, what does it take to fill the system?
The cans are 12oz I believe.
......depends on capacity of system and how much currently remains in same...there shoud be a data plate/sticher either on the compressor or on the body of the heater core cover that should state the capacity...a set of gauges is the ONLY SURE WAY of getting an accurate reading....
Old May 5, 2008 | 04:37 PM
  #35
Da Mail Man
1 can for you....and 1 can for me should fix your problem!
......grin, how does "1 can for you" recharge his system?
Old May 5, 2008 | 04:38 PM
  #36
Da Mail Man
Just checked. I have FOUR 14oz cans. However, one is empty, guess over time it leaked out. So I have three cans, 14oz each.
That should be enough, no?
I also have the hose adapter for the can.
Problem. It's FORD MOTOCRAFT R12. Kinda like Jerry Sienfeld getting a blood transfusion from Newman, eh?
......the manufacturer of the refrigerant means nothing..the type of refrigerant does.....
Old May 5, 2008 | 04:39 PM
  #37
Da Mail Man
COOL!! So the entire system holds 36 ounces, I have enough and then some......excellent.
As for the 8oz of oil, is that in the freon, or do I have to get it separately? Is it as expensive as the gas?
.....needs to be added separately....getting a bit hard to find though.....
To AC Question
Old May 5, 2008 | 04:41 PM
  #38
Da Mail Man
No, there is no oil in the R12 cans you have, unless it explicitly says so on the can.....It will probably be difficult to find R12 oil charge nowadays. Chances are, since your AC system is still cycling , you still have plenty of oil in the system....
Remember....make sure you first try to locate the leak. If you find that you have a bad hose, BLAM, it will have to be replaced, system will have to be evacuated, and re-charged. If this is the case, good to replace the oriface tube(chap) and the reciever dryer....
On the other hand, if you can't find a major source of leak, I would just give a quick "torque" to all the connections, hook up the gauges and charge to specified High/Low pressure....(I don't know these numbers off hand....)
A good rule of thumb is ~30psi on the Low side and ~200psi on the High.......
.... on finding the leak...if not visible, could be in teh evaporator housing....you could use a leak detector for that one by placing prob of same in vent...
Old May 5, 2008 | 04:46 PM
  #39
Da Mail Man
...uh....once the system is open, it has an affinity for moisture and will absorb same VERY quickly!....change out the orifice tube as well as the accumulator/dryer...i have never heard of anyone sucking down a system with a "shop vac" (or similar!)...it would seem to me that any vacuum cleaner WOULD NOT be sufficient to pull a hard enough and steady vacuum on the system...i WOULD NOT USE IT...pulling a vacuum is for removing air from the system and when the system is under vacuum it lowers the boiling point of the refrigerant so that the moisture will "boil off" and be removed by the vacuum pump.....moisture and refrigerants in the system together will form an acid, taking out the system over time.....once you put on a set of gauges and pump the system down,turn off the pump, shut all valves, mark and watch all gauges for about an hour...if the gauges move at all, you have a leak which must be fixed....
Last edited by Da Mail Man; May 5, 2008 at 09:33 PM. Reason: additional and spelling errors
Old May 5, 2008 | 04:47 PM
  #40
Da Mail Man
....you will still have to vacuum it down as i stated previously!
