AC Question
Old May 4, 2008 | 07:49 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default AC Question
OK, everything is together and seems to be running great. I pulled some plugs today and they look fine. Still new, they need more miles on the to turn brown I guess.
Anyway, this has been going on for some time, even before the mods.
With the AC on the compressor will run for about 3 seconds, then shut off for about 4 seconds, then run for three seconds, then shut off for about 4 seconds.
The idle goes up and down, as it should, when the compressor cycles.
Now, the AC lines get ice cold as they should and the system blows very cold.
So the AC is doing the job it was designed to do, however, is the compressor supposed to cycle like that?
Other than the idle going up and down, there's no problem. It's just a little annoying.
Old May 4, 2008 | 08:07 PM
MikeC4's Avatar
MikeC4
on/off cycling of the compressor is normal to keep the evaporator from freezing up, however, 3-4 second intervals of cycling is to frequent. This will lead to early clutch failure. My guess is that your oriface tube may be clogged.
Old May 4, 2008 | 08:08 PM
jsup's Avatar
jsup
I don't know AC, what is an oriface tube, and how can I tell if it's really clogged?
The car has 33K miles and is in mint shape. It has always been garaged. Does that mean anything to you in terms of the tube clogging?
The system is R12 and if I have to evacuate it I just may wait for the clutch to go.
Old May 4, 2008 | 08:23 PM
MikeC4's Avatar
MikeC4
Let me just throw out a quote here:
Metering devices are used to regulate the flow of liquid refrigerant into the evaporator. They also serve as one of the two junctions between the high and low sides of the system. There are two basic types of metering devices used in A/C systems: fixed and variable.
Oriface Tube:
This is a fixed metering device(which is what our vettes have) located inside the liquid line between the condenser and evaporator. The orifice tube is enclosed within a plastic housing and protected by a fine mesh filter. The filter prevents debris from clogging the tube.
Yes, that is low miles, but do you know if the AC system has previously been serviced ?
Old May 4, 2008 | 08:27 PM
jsup's Avatar
jsup
Oriface Tube:
I don't know if it's been serviced. When you say serviced, what do you mean? My extent of AC knowledge resides in understanding the role of the compressor, evaporator, and condenser. Short of that, I understand the high and low pressure cutoff switch. But that's about as far as it goes.
I guess if my question is will a service solve/identify the problem (if it turns out to be that) or does the system need to be evacuated, taken apart, fixed, and reassembled and recharged?
Keep in mind, it's still R12. Is this going to be a problem?
Old May 4, 2008 | 09:01 PM
Fick's Avatar
Fick
I recently had mine serviced, the refrigerant was very low. According to the tech, when it gets very low the compressor cycles on and off continuously in an effort to cool.
Old May 4, 2008 | 09:03 PM
Yellow2015's Avatar
Yellow2015
It sounds like the compressor is short cycling. One of the most common causes is low freeon charge. The suction line is getting cold from the rapid rate of the cycling. I'd check your charge before ripping into the system to replace the orifice. If you have to replace it, take the old one to a pep boys and they can sell you a replacement based on the number stamped on it.
Of course if you don't have the license to buy the freeon, you're better off having it done by someone who does.
Old May 4, 2008 | 09:10 PM
jsup's Avatar
jsup
Like I said, I don't have the tools or the knowledge to do it, so I will be taking it somewhere.
My concern is the R-12..I know someone in the AC business, hopefully they can help. I have two 1lb cans of R12 on my garage shelf, and a charge kit, hope we can use those.
Old May 4, 2008 | 09:18 PM
Da Mail Man's Avatar
Da Mail Man
..... ....it really sounds like you have a low charge....some shops will throw on a set of refrigeration gauges for little of no cost and that should tell the tale....a clogged orifice tube will also show up as high pressure on the gauges......
Old May 4, 2008 | 09:21 PM
MikeC4's Avatar
MikeC4
Fick and GA are right on the money and I apologize for missing this. What you need to do is visually look at all your AC connection points for residue from a leak. Check the rubber hoses as well, as they can also develop pin hole leaks over time. I too have an R12 system in my '93, and this stuff costs more per ounce than gold !! (not really, but it will cost alot, assuming you can find a shop that still deals with R12).
yoitsmatt's Avatar
yoitsmatt
Easiest way to see if its low charge, turn a/c on full cold with max fan speed, the compressor should stay running or only cycle every few minutes, if compressor is still cycling fast, feel both lines coming through the firewall, if one is alot warmer than the other it very likely low on charge, someone with an old set of guages should be able to use the cans you have.
Old May 4, 2008 | 09:22 PM
jsup's Avatar
jsup
Thanks everyone.
Cool, I'm going to have it measured.
I have 2 cans of R12 in the garage, what does it take to fill the system?
The cans are 12oz I believe.
Old May 4, 2008 | 09:28 PM
Yellow2015's Avatar
Yellow2015
Originally Posted by jsup
Thanks everyone.
I don't know the exact charge but 2 12 oz cans (1lb 8 oz) should be enough. Check the data plate in the engine compartment. If it IS low, and since you only have 2 cans of R-12, make sure they leak check the system before charging it.
Old May 4, 2008 | 09:30 PM
MikeC4's Avatar
MikeC4
Thanks everyone.
1 can for you....and 1 can for me should fix your problem!
Old May 4, 2008 | 09:36 PM
jsup's Avatar
jsup
Just checked. I have FOUR 14oz cans. However, one is empty, guess over time it leaked out. So I have three cans, 14oz each.
That should be enough, no?
I also have the hose adapter for the can.
Problem. It's FORD MOTOCRAFT R12. Kinda like Jerry Sienfeld getting a blood transfusion from Newman, eh?
Old May 4, 2008 | 09:41 PM
MikeC4's Avatar
MikeC4
OK, now it's 2 for you, and 1 for me !!!
Here ya' go:
Old May 4, 2008 | 09:44 PM
jsup's Avatar
jsup
COOL!! So the entire system holds 36 ounces, I have enough and then some......excellent.
As for the 8oz of oil, is that in the freon, or do I have to get it separately? Is it as expensive as the gas?
To AC Question
Old May 4, 2008 | 10:06 PM
MikeC4's Avatar
MikeC4
No, there is no oil in the R12 cans you have, unless it explicitly says so on the can.....It will probably be difficult to find R12 oil charge nowadays. Chances are, since your AC system is still cycling , you still have plenty of oil in the system....
Remember....make sure you first try to locate the leak. If you find that you have a bad hose, BLAM, it will have to be replaced, system will have to be evacuated, and re-charged. If this is the case, good to replace the oriface tube(chap) and the reciever dryer....
On the other hand, if you can't find a major source of leak, I would just give a quick "torque" to all the connections, hook up the gauges and charge to specified High/Low pressure....(I don't know these numbers off hand....)
A good rule of thumb is ~30psi on the Low side and ~200psi on the High.......
Old May 4, 2008 | 10:12 PM
jsup's Avatar
jsup
I just read through the FSM. Those numbers are in there.
I'll copy that page and bring it with me.
Even if the entire system needs to be evacuated I have enough Freon.
I am going to do the following:
1. Perform a leak test
2. If leaks, fix them and fill it
3. If no leaks, top it off and keep the R12
If I have to refill it I have to find R12 oil. I did a quick Google and it seems to be available.
Make sense?
Old May 4, 2008 | 10:19 PM
MikeC4's Avatar
MikeC4
Yes, sounds good....but if you have to:
You will need to draw down the system(ie vacuum down) to remove moisture from the system before you "fill it". Once you open your system to the atmoshere, air and mositure immediatley enter.....When I do R134 work, I duct tape an AC hose to my shop vac and hook it up to the Low side and let it suck for 30 minutes, then do the same on the High side....I have never had any problems with this method... I just refuse to pay these rediculous prices to "AC specialists" for work....It 'aint rocket science as they would have you believe....It's simple closed system refridgeration that has been around for decades!!!
