C4 Intermitent Problem When Warm (please Help!!!)
Old May 5, 2008 | 08:48 AM
JJ2000's Avatar
JJ2000
Default C4 Intermitent Problem When Warm (please Help!!!)
Hey guys, im sure some of you will read this again as this is the third time im posting, all the feedback was great but unfortunity im still having an issue and im very frustrated, so here is the deal, i have a 1994 lt1 and this problem only happens when the car is warm, never ever does it cold, car starts up fine, then rpm's drop and is either starving or lacking fuel, after about 20 secs it stop and car drives perfect, never does it at a light only at intial start when warm..and the weird part is sometimes its fine...im pretty sure this is a fuel issue not a tune-up/elec issue, some have said fuel presure reg, any way it could be this????i need some feedback from you experts, i have replaced coolant sensor that feeds computer, i have cleaned TB, i have done top engine clean, fuel injector clean in fuel, dont know what the next thing to check, please help this is driving me nuts!!!!
Old May 5, 2008 | 08:54 AM
aminnich's Avatar
aminnich
Pull the vac line off the FPR, if it smells like gas then the FPR has gone south on you.
Old May 5, 2008 | 09:02 AM
JJ2000's Avatar
JJ2000
i did, it only had maybe a slight smell, but im not sure....
Old May 5, 2008 | 09:06 AM
JJ2000's Avatar
JJ2000
so the fpr can cause this intermident problem, is this an expensive part and hard to replace?
Old May 5, 2008 | 11:41 AM
JJ2000's Avatar
JJ2000
Any Possibility This Can Be A 02 Sensor Problem??????
Old May 5, 2008 | 01:09 PM
jhammons01's Avatar
jhammons01
I'll bet it is a leaky injector issue. Injector clean in the gas tank will not address this issue. you have to pull them and take them to a diesel shop who physically cleans them.
Old May 5, 2008 | 01:23 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If you feel it is a fuel problem, then buy a fuel pressure gauge that screws into your fuel rail, tape it to the windshield, and go for a ride. When the car acts up, see if the fuel pressure is the same, or if it goes down. If it stays the same, it is not the fuel.
How many miles on the car? Has the opti been changed?
Randy
Old May 5, 2008 | 01:29 PM
aminnich's Avatar
aminnich
FPR is normally either good or bad, not intermittent, but then it was any easy check. You would have known it if there was gas in the vac line. I am tending to agree with RandyJ75 about a fuel pressure gauge and a road test. An o2 sensor should have thrown a code. Another question (easy one again), since you replaced the ECT sensor on the water pump is your digital gauge working correctly? have you had it scanned for any historic/active codes?
Old May 5, 2008 | 02:48 PM
JJ2000's Avatar
JJ2000
yes the gauge is working fine, it NEVER does this while driving, only at intial start up when the car is anything but cold, this is not a opti problem as we have ruled this out already, the car has 46k miles on it, what would cleaning injector due to stop if leaking, there is no smell of fuel in engine bay....
Old May 5, 2008 | 03:55 PM
jfb's Avatar
jfb
One or more injectors could be leaking when hot and not every time. You shut off engine, injector leaks liquid gasoline, you start up and engine runs poorly due to over rich condition until the rich condition is cleared out by air passing through running engine, injector doesn't leak fast enough to hurt running engine. If it is this, then the only way to fix is to let someone with complete injector test facility that can heat the injector and put fuel pressure on it and watch to see if it leaks and keeps trying until it finally leaks. Intermittent problems are the hardest ones to find!
Old May 5, 2008 | 03:59 PM
Gramps96's Avatar
Gramps96
I just developed the same symptom. Usually only does it when started. After it is running a while, no problem. I just finished installing my 502 Comp Cam, Exotic Muscle long tube headers, and had a tune from PCMforless. So, I'm talking with Bryan Herter about it, and he thinks it is an O2 sensor acting up. Especially, since it stops after it has been running a short while. I assumed I would get a code if it is an O2 sensor but Bryan advises that an intermittent problem may not throw a code. I'm feeling pretty confident in Bryan's skills so it looks like I'm going to buy two new sensors and see what happens. Any suggestions on which ones to buy?
Old May 5, 2008 | 04:00 PM
JJ2000's Avatar
JJ2000
how do you fix a leaking injector? some have said to have them professionaly cleaned, would this help?
Old May 5, 2008 | 04:06 PM
JJ2000's Avatar
JJ2000
keep in touch hopefully we can help each other out cause im going nuts over this problem!, its my fiances car but its really bothing me! well i just replaced my coolant sensor, (the one bye the water pump) and that did nothing, so i need some advise too as to which o2 sensors to replace, i was told same thing that they will not through a code unless they are really shot..its an air or fuel issue for sure .AN SUGGESTIONS ON THE SENSORS
Old May 5, 2008 | 10:33 PM
94LT1VETTER's Avatar
94LT1VETTER
the 02 sensors closest to the engine are the ones the ecu uses to make a/f adj's. The ones after the cats are to ensure the cats are there and are working properly.
Try the fuel Pressure test, and tape the guage to the windshield and watch it for a while. It should hold pressure for a while even after shutting off the engine. This should tell you if leaking injectors are suspect.
Yeah, if your temp guage (the digital one you can call up, NOT the needle one) works well, not that simple... sorry.
For the helluvit, try bleeding your coolant too.
BTW... who changed the CTS? Check and make sure that the connection is good. If it starts acting up wiggle and push the connector for that one (yes the one in the water pump). If it settles out then it's the connection. This connector can be damaged during a serp belt un-tensioning. I'm the one that messed mine up, but I found the prob so... cool.
To C4 Intermitent Problem When Warm (please Help!!!)
