code 32
Old May 10, 2008 | 09:45 PM
RG86VET's Avatar
RG86VET
Default code 32
86 vet has been running fine, tonight on interstate running constant 70 mph for 30 miles ,service light comes on ,stays on for about 25 min until i got off at exit and opened her up , the light then went out. has not came back on , should i be worried?
Old May 10, 2008 | 10:19 PM
guido7834's Avatar
guido7834
I had same situation with my 87. Light went out and didn't show up again. About a week or so later, oil started pouring out. Turned out to be the oil pressure switch. I am no expert but the SES light must mean something
Old May 11, 2008 | 01:08 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
check for codes 1st, then go from there
Old May 11, 2008 | 03:46 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The EGR system (on your year) has three elements, i.e. EGR Valve, EGR Sol, EGR Temp Sw; there is a method on my site to test these elements to determine if one is malfunctioning.
It sounds as though the ECM is calling for EGR while cruzing but is not detecting the valve opening.
I run a 160deg T-stat so my ECM rarely tries to open the valve except on hot summer days.
Old May 11, 2008 | 08:42 AM
RG86VET's Avatar
RG86VET
Default reply
i checked the code and the only code that is coming up is 32, but the car is running fine, no problems yet
Old May 11, 2008 | 08:48 AM
RG86VET's Avatar
RG86VET
Default reply
is it ok to drive with this issue??
it is my dd
Old May 11, 2008 | 08:51 AM
TA's Avatar
TA
it is my dd
Yes, you'll be fine.
Old May 11, 2008 | 10:44 AM
rick lambert's Avatar
rick lambert
Same thing happened to my 87, when I did a search here someone stated 95% of the time it's the EGR switch, 10-15 bucks, about 15 minutes work and it solved my problem.
Old May 11, 2008 | 12:25 PM
RG86VET's Avatar
RG86VET
Default Egr Switch
Where Is The Egr Switch?
Old May 11, 2008 | 12:36 PM
RG86VET's Avatar
RG86VET
Default Ceramic And Wire
On The Right Side Of The Engine Where The Tube With The Silver Insulation. The Wire That Goes Into The Ceramic Piece Is Loose. The Wire Goes Behind The Distributor. Can I Unplug The Wire And Screw That Wire Into The Ceramic. Will It Or Not Screw In. But I Can Tell You The Wire Is Very Loose. Could That Throw A Code 32?
A Loose Wire Still Connected But Alot Of Movement
Old May 11, 2008 | 01:19 PM
65Z01's Avatar
65Z01
When I had the intake base off I moved that connector up to the RH side of the dist for easy access. In your case I'd just cut that green wire and splice in a new connector with a little more wire.
Since the ceramic top is loose I'd say you have found the culpret...
Old May 12, 2008 | 10:53 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2032.pdf
To code 32
