Codes 33 and 36
Old May 11, 2008 | 07:43 PM
Raidmagic's Avatar
Raidmagic
Default Codes 33 and 36
What causes them and what fixes them?
Code #33: Mass Air Flow Sensor High.
Code #36: Mas Air Flow Sensor Burn-Off Function Fault.
I'm also having a rich start issue I don't know if they are connected or not though.
Mods are 1-3/4 long tubes 3" exhaust, x-pipe, cats, no mufflers.
ATI procharger Holley Stealth Ram. Stock heads and bottom end. It's an 87 BTW
Old May 11, 2008 | 08:12 PM
cbryant's Avatar
cbryant
Did the codes appear after the Procharger install? Did you have the chip burned to accomodate the mods?
Old May 11, 2008 | 08:34 PM
Raidmagic's Avatar
Raidmagic
Yes and yes, The car has been running great untill recently it's hard starting real rich. I have to rev it to clear it out then it runs fine. So I pulled the codes and those came up.
Old May 12, 2008 | 10:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2036.pdf
To Codes 33 and 36
