engine troubles....what i found!!
Old May 14, 2008 | 03:14 PM
corvette90's Avatar
corvette90
Default engine troubles....what i found!!
maybe you remember last, when a clacking noise started in my engine..
anyways, today i found a piece of junk in the oil bore from a lifter....
i inspected carefully, and found more junk in the oil passages of the block...
now i know, why...
in the GMPP block, the oil pump feed line is straight up to the oil pressure sending unit...and..this line should be plugged aprrox 1.5 inches deep in the bore...guess, what the engine builder forgot..exactly this plug..so, the uncleaned oil went straight to all bearings, not the filter.....
greetings
Old May 14, 2008 | 04:19 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
OUCH, sorry for your luck. Hope your builder takes care of this.
Goodluck!!
Old May 14, 2008 | 07:15 PM
85 500 horse's Avatar
85 500 horse
Goodluck!!
His builder better make it good. I know if it were me and he didn't, he'd be taken to court mighty quick.
Old May 15, 2008 | 03:47 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I'll bet he says even the space shuttle crashes once in a while.
My buddy had his engine builder tell him that.
Lucky he had me and my buddy around,We built him a new motor.
Old May 15, 2008 | 08:43 AM
corvette90's Avatar
corvette90
i would say, you win the bet...
its 3 years ago, that he assembled the short block (mainly to see, if the cam clears), i have driven only about 3000 miles, due my lack of time..
i brought the crank to a machine shop, it seems, that the minor scratches can be polished...
greetings
Old May 15, 2008 | 09:17 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
OH MAN, I can't believe it, someone who has worse luck than I do....
Keep us posted on the results...
Old May 15, 2008 | 02:17 PM
rons85's Avatar
rons85
With All of the many motors I've built (years of working at a machine shop...) I put together a nice little SBC for a friend once, for use in his '69 Z-28. Nothing too expensive, but nice. Forgot that darn plug (after hot-tanking the core block) during the build. The thing lasted about a week before toasting the bearings - he was Not happy. At least it was a friends deal, not a paying customer. You can bet that I haven't forgotten that darn little plug ever again
Old May 15, 2008 | 05:14 PM
corvette90's Avatar
corvette90
good news...the machine shop called me today, the scratches was so minor, they polished them out, and the crank is fine again..will order the other parts tomorrow, and i hope, i´m on the road again in about 2 weeks...
To engine troubles....what i found!!
