Crossfire or Carb?
Have you seen this site? It's all about Cross-Fire and you can learn a lot about the cross-fire, and how to improve the performance.
http://www.crossfire.webhop.net
YOu might want to look back a couple pages on the C4 General Discussion Forum. CFI vs. TPI was covered quite extensively(and I apparently appalled some because I didn't say CFI was a good setup, apologies to those people) and there is some good info there.
Bottom line, it's about what you want to do. Making a motor run well is all about building the proper combination. You can have a huge cam and stock exhaust/induction system and it'll probably run worse than stock configuration(Although have that nice 'drive in cam' sound:)). Similarly, you can have the best intake with the incorrect head/cam combo.. The motors that some people build, which are *very* fast for very little money are the ones where people know how to match engine components together. It's a gift for some, the luck of the draw for others.
I've invested about 2500(maybe 3K including *everything*) in my '84, choosing carefully the engine components that would work well together. That's very difficult to do as the CFI manifold is so restrictive once you do other mods to the motor(the intake runners a tad more than half the size of those on the head). I've turned a *best* time of 13.39@104.**mph in my '84(cool night, near perfect run, street tires); under 'normal' racing conditions(if there is such a thing;)) It'll run 13.5-7@101-102mph. Some may say that's *fantastic* performance for an '84 and I agree... for a CFI setup. In fact, I only know of one other '84 with the CFI intact that has turned a better time than 13.39. That was some guy from Canada(12.92, but he had 3.73 gears), under more than ideal conditions(meaning calculated below sea-level air).
If I would have yanked the CFI off to install a carb,(and was willing to sacrifice 25-27mpg at 80mph, great throttle response, and the fact that my car runs pretty good with the CFI on, worth bragging about to anyone really;)) put 2500 bucks in the motor, building a combination to suit that induction system, I'd probably be running low 12s at 110 or so mph. Again, I'd lose a lot of driveability(probably 15mpg highway) and it's difficult to get anything other than a Performer 4 barrel intake to clear the C4 hood (Performer RPM will not).
So, my recommendation? If you want to do more than getting your '84 to run low 14s or high high 13s on a good night, look at 1)getting another car or 2)be prepared to spend some bucks. That's my .02 and I'm speaking from 10+ years of modifying my '84. I love the car, will never sell it, but it is what it is, and that's a mediocre running car(by today's standards) with a compromise for an induction system. I'll end this post with something Dave McLellan said when I asked him many years ago what I could do to make an '84 fast. He surmised, "Yank the Crossfire off." :):)
You might want to check it out, he was selling them for around $300-400 I think.
[Modified by AquaMetallic94LT1, 6:31 PM 12/18/2001]
You ARE kidding , aren't you? Do you recall the 7 or more e-mails we swapped back and forth between 12/2 and 12/9? You even sent me pictures of your air scoop. YES, I do "drag my vette"!
Jim
http://drive.to/joby
Engine is compleatly stock exept for modified swirl plates. I removed all emissions stuff and installed a true dual exhaust with headers and x-pipe.
I measured close to 300 rwhp ( at 10 psi boost )
G-Tech numbers:
1/4 mile 12.73 sek 116.3 mph
0-60 mph 4.73 sek
that is untill they start tinkering with theirs
The Performer Rpm does fit. I've ran it along with many other intakes while sorting out different combos. The Rpm works best with a 1 inch spacer, however don't think about running an air cleaner, it won't fit. :cheers:
