Another Hurst question
Old Dec 18, 2001 | 06:26 PM
snaketr's Avatar
snaketr
Default Another Hurst question
Does the Hurst retain the reverse lock-out lever or is it crash through like the 96' and the B&M.
Old Dec 18, 2001 | 08:06 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Another Hurst question (snaketr)
The Hurst does away with the lockout ring so it will be like the '96.
[Modified by Tony.96LT4, 2:05 PM 12/19/2001]
Old Dec 18, 2001 | 09:23 PM
DSTJ99's Avatar
DSTJ99
Default Re: Another Hurst question (Tony.96LT4)
Does anybody have any general comments on this mod. This seems like a decent deal for $140 i thought i saw here? Scares me even touching the ZF6 though. IAlready had one replaced under warranty, i wouldn't want them to pin it on a mod if happened again.
Old Dec 18, 2001 | 11:18 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Another Hurst question (DSTJ99)
I thought this was one of the best things I did so far to my car. The short throw shifter (and that's any of them out there) will increase your driving enjoyment. If you do a search you'll see there is a divided camp, B&M on one hand and Hurst on the other. Even the guys with Kirbans and the stock shifters got into it. I felt the Hurst was the way to go not only cost wise but in what others had said about the B&M. I ran Hurst years ago and always liked their quality, this new shifter is no exception. The quality is outstanding, the instructions are clear and the only thing you are changing is the actual stick itself. You reuse all the other stock parts. Can I throw a flat shift faster than before with the stock shifter? I don't know, but I am more confident throwing them now. I've had mine in for around 5 months and it still feels the same as when I put it in, and no rattles. It's a great deal for the money. Just my comments. Do a search in this section using Hurst and read what has been said. You'll be hearing from the other camps shortly. :D
Old Dec 19, 2001 | 09:30 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I agree with Tony. Also, reverse lock out on the early ZF I wouldn't worry about it. Mine doesn't have a reverse lock out and the Hurst has been on the for about 8 months as my DAILY. The only time I hit reverse was just after the shifter going from 4th to 6th skipping 5th just after the shifter getting used to the closer gates. I love mine totally changed the ZF. When are you going to be shifting into 6th so quickly you hit reverse?
Old Dec 20, 2001 | 12:39 PM
90pololt4's Avatar
90pololt4
Where can I purchase the Hurst Shifter and the best price? Has there been a GP on any? I have always liked the way the Hurst shifters have worked for me. Thanks
Old Dec 20, 2001 | 02:34 PM
Chris@SD's Avatar
Chris@SD
Default Re: Another Hurst question (90pololt4)
We are selling them for $129.95. I have one left as the other one is reserved for someones car! I wonder who that could be.... :) :)
Old Dec 20, 2001 | 04:44 PM
90pololt4's Avatar
90pololt4
Just ordered one hurst shifter from Chris. Thanks for the quick service.
To Another Hurst question
