shift points
Old May 29, 2008 | 12:52 PM
93stroked's Avatar
93stroked
Default shift points
Hello, I have a 4L60E and i'd like to change the 2-3 shift point to a higher rpm, can anyone one tell me what program i would need to do this? Thanks
Old May 29, 2008 | 12:56 PM
rickneworleansla's Avatar
rickneworleansla
For my 95.... TunerCat and the correct definition file for programming. Also needed are a cable and a laptop. Datamaster TTS can be used for datalogging. PCMFORLESS could email you a custom tune for $75.
http://www.tunercat.com/
http://moates.net/
http://www.ttspowersystems.com/
http://www.pcmforless.com/
Old May 29, 2008 | 01:11 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Did you swap your tranny, the 93 came with the 4L60 and it is a one year wonder.
Old May 29, 2008 | 01:53 PM
93stroked's Avatar
93stroked
No it's a 4L60E they don't make a 4L60 before the 4L60E it was the
TH700R4
Old May 29, 2008 | 02:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
No, you are mistaken. The E at the end represents it as a electronic transmission, which the 1st year for that is 1994. Like I stated earlier, the 93 a4 is a one year wonder. If you do a search on this site, you will see that I am right.
If you have a TV cable coming out of the ASR and going to the tranny, it is a 4L60.
Old May 29, 2008 | 02:38 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
The TH700R4 and the 4L60 are the same transmission. The 4L60-E is different because it is "Electronically controlled"
Old May 29, 2008 | 02:39 PM
93stroked's Avatar
93stroked
ok your right... so how would I change the 2-3 shift point, right now it shifts from 1-2 at 6700rpm and 2-3 at 5800rpm Thanks
Old May 29, 2008 | 03:05 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
That sounds like an internal problem, send a PM to petek. He is the tranny guru.
Old May 29, 2008 | 03:19 PM
93stroked's Avatar
93stroked
It acutally has a shift kit in it, I wanted it to shift 2-3 @ 6500...how do I PM petec?
Old May 30, 2008 | 08:04 AM
bjankuski's Avatar
bjankuski
If the transmission has a TV cable you need to modify the governor on the rear drivers side of the tailshaft to change the shift points. B&M sells of governor calibration kit that allows you to make the changes. If you have an electronic controlled transmission you can have it reprogrammed. A stock 1993 will have a TV cable.
Old May 30, 2008 | 09:05 PM
schrade's Avatar
schrade
If you've had the TPS unplugged without disconnecting the battery, the shift cycle will string out to high RPM's, before it re-learns your drive style - usually a couple of days' driving...
Old May 30, 2008 | 10:04 PM
Kool88vette's Avatar
Kool88vette
You want it to shift at 6500 RPM? A heavier governor might help. It works in a 700R. I'm not sure about your tranny.
To shift points
