Installing torque converter dry, will it work?
Old Jun 11, 2008 | 12:55 AM
86GoldProject's Avatar
86GoldProject
Default Installing torque converter dry, will it work?
Having a debate on another board, the guy says if you install a torque converter without any fluid in it it will fill up on its on after letting the car idle for a while. I've always been told to fill the converter before installing it or you will have to pull the trans again to fill the converter as it will not fill on its own. Who is right?
Old Jun 11, 2008 | 03:14 AM
bigwave71's Avatar
bigwave71
it will fill up on its own but it will suck the pan dry very fast and you will have to shut the car of to refill the pan. not recomended you do that, i would put at least two quarts in converter then put it on the trans.
Old Jun 11, 2008 | 03:16 AM
khhammer's Avatar
khhammer
Originally Posted by bigwave71
it will fill up on its own but it will suck the pan dry very fast and you will have to shut the car off to refill the pan.
Old Jun 11, 2008 | 05:40 AM
makn u shiver's Avatar
makn u shiver
every converter i ever used had a warning to fill the converter with at least 1 liter before you install it ,i put in 2 liters .
Old Jun 11, 2008 | 07:30 AM
Da Mail Man's Avatar
Da Mail Man
.... out of all the converters i have installed, i have never installed one with out filling one to the bottom of the "neck"...i do the same with oil filters when doing an oil change.....
Old Jun 11, 2008 | 11:12 AM
Hotred94's Avatar
Hotred94
I recently did mine and I recommend using Dextron VI fully synthetic. I've seen the GM specs on it and that stuff is way superior to Dex III.
Old Jun 11, 2008 | 11:18 AM
Pete K's Avatar
Pete K
You can install it dry, but why would you?
Nothing good happens when something hydraulic does not have fluid.
Old Jun 11, 2008 | 11:38 AM
Hotred94's Avatar
Hotred94
I just saw Pete's assessment on synthetic oil. Now I'm thinking twice about it and hoping this opinion doesn't extend to the new Dex 6 which is what GM is now recommending in place of Dex 3. What do you think Pete?
Old Jun 11, 2008 | 12:47 PM
Demonic85's Avatar
Demonic85
could hear some nasty metallic noises
Old Jun 11, 2008 | 01:30 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Always put fluid in the convertor before installing.
Old Jun 11, 2008 | 06:15 PM
JimiHendrix's Avatar
JimiHendrix
What is the harm in putting a liter of tranny fluid in the TC before installing? Takes a second.
Here's to your friend....
To Installing torque converter dry, will it work?
