This will make you think!!!
Old Jun 11, 2008 | 11:29 PM
ol school's Avatar
ol school
Default This will make you think!!!
Just wanted you guys that have never seen the front side of your radiator,because its hidden by a couple of items..well i had to replace mine and i took some photos,you'll be surprise.....!!!!!
so the above photo is the overall front of radiator..
the above photo is the lower corner.LOOKS LIKE A BIRDS NEST!
another view of the lower section where radiator sits...
this is just to let you see whats going on under your hood..
you may want to remove your shroud one day and clean ..
Old Jun 11, 2008 | 11:38 PM
janarvae's Avatar
janarvae
I bet you're glad you're cleaning that now, huh?
Last edited by janarvae; Jun 12, 2008 at 08:02 AM. Reason: He got the pictures to work.
Old Jun 12, 2008 | 07:03 AM
69mako's Avatar
69mako
Thats why I put a skinny extension on my shop vac and clean out that area every winter
I also blow air from the back side to clean out what is stuck between the fins.
Old Jun 12, 2008 | 07:50 AM
bd2626's Avatar
bd2626
Well, I'm doing a water pump on my 89 so I guess this will be a part of the to-do list!
Old Jun 12, 2008 | 07:59 AM
runner140*'s Avatar
runner140*
Me too.
Old Jun 12, 2008 | 01:03 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Quite a find isn't it? I've seen worse, mine for one. This type of thing is why guys complain about running hot. If a car is going to run 220* it doesn't matter if you have a 160, 180, or 195 stat in it, it's still going to run 220*. Doing maintenance like this, having the radiator cleaned out, and having the ECM programmed to turn the fan(s) on sooner are the ONLY things that will bring running temps down.
Old Jun 12, 2008 | 03:42 PM
schrade's Avatar
schrade
Looks like Granola Trail Mix... How's it taste?
Old Jun 12, 2008 | 07:43 PM
Happydad's Avatar
Happydad
Don't start the Stat Thing....
Old Jun 12, 2008 | 11:49 PM
Midnight 85
Where do you get the idea that I was? I was downplaying stat changes in favor of routine maintenance.
Old Jun 13, 2008 | 12:37 AM
DDSLT5's Avatar
DDSLT5
Very true! Once the rad is clean, the fans are reprogrammed, and maybe a higher capacity rad, with a lower stat, then temps will dip to where you want them (wherever that may be depending on your plant).
And yes - the rad needs to come out! The vette is a vacuum cleaner for the road - has been since the C3 - anyone who tells you differently is running a little 'hot' himself!
Old Jun 13, 2008 | 02:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I pulled the fan and radiator shourd earlier this year to be sure all was well before the summer months...
To This will make you think!!!
