DUI Distributors
Old Jun 13, 2008 | 08:44 PM
ultraviolet70's Avatar
ultraviolet70
I just did a little more research and what I found was some iron gears are compatible with the roller cams and some are not, one comment I found specifically mentioned MSD distributors iron gear were having issues. The fix is easy you simply have to replace the gear with a melonized gear. I know personally for the small cost and little amount of time involved it'd be worth the piece of mind to swap it out.
GM part number for gear is 10456413
