Plenum porting - question!
Old Dec 22, 2001 | 06:58 AM
Sliding's Avatar
Sliding
Default Plenum porting - question!
I'm about to start with plenum porting. In past few months I have collected a lot of infos about this and I think it shouldn't be a problem. I'm only worried about error and SES light that could apear afterwards.
Is it still possible to drive the car with SES light and error on?
I found some infos about EPROM programing and I hope that soon I will be able to do programing myself but until that I would like that I can drive my vette normally.
Also if anybody have infos about EPROM programing or good links I would be very thankful.
Thank you! :)
Old Dec 22, 2001 | 09:46 AM
vettedreams's Avatar
vettedreams
Default Re: Plenum porting - question! (Sliding)
I just finished porting the plenum, runners and intake on my L98 and she runs better than I expected! and best of all no codes, good luck! by the way that was a stock intake system that i ported, not stock anymore. :smash:
Old Dec 22, 2001 | 11:21 AM
dbelnap's Avatar
dbelnap
You should have no problems error codes by porting the plemum & runners. There is lots of good info in the forum ifyou search both active and archived posts. About a year ago there was a series of pictures (before and after) that a fellow forum member posted that was excellent.
Old Dec 22, 2001 | 01:43 PM
vader86's Avatar
vader86
Default Re: Plenum porting - question! (dbelnap)
yes you can drive the car with the SES light on, but if you got a code resulting from your porting, the car will probably run very crappy.
Old Dec 22, 2001 | 03:03 PM
Sliding's Avatar
Sliding
I'm OK with plenum and runners but how should I port the intake?
Some pics maybe?
Old Dec 22, 2001 | 03:14 PM
BobMachus's Avatar
BobMachus
check out these pix of a Lingenfelter-ported GM base
http://mike89gta.bravepages.com/
Old Dec 22, 2001 | 03:26 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Plenum porting - question! (BobMachus)
It depends on HOW you want to port the plenum..usually a good gasket matching is all thats required for the main holes.
I installed the gaskets and looked to see how much material was still in the way and used a pencil to make marks around the circles and then grinded the walls rounder with a dremel tool and cutting bit.
Take my advice...use ALOT of duct tape around the places youre not going to grind smooth..its easy to slip and gouge the flat surfaces by mistake.The duct tape will help stop the damage if you slip.
ANother reason the car feels more alive after some minor porting is because usually its very dirty in the plenum and runners..once youre done porting and have them cleaned out, they flow alot better.
Its amazing how much carbon builds up in there over the years.
I brought my pieces to a machine shop and they boiled it in the hot tank and got every trace of the black stuff out.They were like new inside and out when done.
Old Dec 22, 2001 | 07:16 PM
pablocruise's Avatar
pablocruise
Did you happen to see the pics of the stock intake I ruined by porting TOO much? I did delete them accidentally off my homepage but I can shoot some new pics no problem. It's a pictorial of how NOT to port an intake :eek: :D .
Old Dec 22, 2001 | 10:54 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: Plenum porting - question! (89 Paul in cal)
Hey would you mind posting them? I am trying to port my lower intake right now and would like to know how "not" to do it:) BTW, what's the best cutting bit to use to port the intake?
Old Dec 22, 2001 | 11:02 PM
Romeo Barrera's Avatar
Romeo Barrera
Default Re: Plenum porting - question! (lowflyer)
If you want to see a real live ported lower (and upper for that matter), I can show ya mine. Sometimes seeing one in person is a heck of a lot more informative than seeing a picture of it. Of course, you'd have to make an excuse to come to the beach ;)
Old Dec 23, 2001 | 12:43 AM
pablocruise
here's some crappy shots(aol digicam :rolleyes: )
pic 1 is the passageway that the exhaust gas flows into. In the corner, I drilled too much and broke thru.
pic2 shows how much wall I took out. Not much left. This is same for all my tracts.
pic3 shows an ol' trick that helps the RTV "grip" alittle better. I centerpunched dimples along the edge of both ends.
pic 4 is the tape measure showing how deep it goes before it hits material.
I just used a dril and drill bit and rotary rasps.
Basically, I had an effect called "reversion" happening in the tract that feeds 5and7 intake valves. 7 fires right after 5 and air wasn't getting sucked in properly. To worsen my situation, I uncovered too much of the EGR holes at the interior bottoms of the intake tracts. The mix was real diluted and car ran like crap.
Sorry for the length on this, but can explain more if ya need.
Moral of my story, be real conservative on the wall that separates 5/7.
[Modified by 89 Paul in cal, 9:00 PM 12/22/2001]
Old Dec 23, 2001 | 01:00 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Good luck :)
Old Dec 23, 2001 | 07:10 AM
Sliding's Avatar
Sliding
Thanks for links and advices.
I will only do some porting because that siamesed thing doesn't look very safe to me, and if something goes wrong I don't know where can I find new intake base in Croatia, and to buy it from US is difficult and pricey.
I will let you know how did things go in about month or so, because I'm waiting for ordered gaskets to come.
Old Dec 23, 2001 | 08:51 AM
Lloyd Smale's Avatar
Lloyd Smale
I did my 86 iroc many years ago no light but no seat of the pants difference either
To Plenum porting - question!
