nitrous question!!!!
Old Jun 15, 2008 | 07:27 PM
white86vette's Avatar
white86vette
Cruising
Default nitrous question!!!!
I recently installed the nitrous works kit on my 86 cp. The kit says to retard the timing....It's been a while and don't remember which way to go....stock is @ 6 btc I have it at 4btc is that right???? Any help is appreciated!!!!!!
Old Jun 15, 2008 | 07:50 PM
white86vette
Cruising
also the car is bone stock so is a 125 wet shot safe???????or should i go with the 50 or 75 shot????
Old Jun 16, 2008 | 06:47 AM
PAINTER MAN's Avatar
PAINTER MAN
That is the right direction.
Old Jun 16, 2008 | 06:03 PM
neat's Avatar
neat
You've adjusted the timing in the correct fashion.
There are a couple other things you can do to make the kit a bit safer. Things like a window switch, fuel pressure safety switch, wide open throttle switch, swap to a cooler plug, etc...
125 is not too much for your stock engine assuming everything is in proper working condition, but that doesn't mean your invincible. A 50 shot done wrong can blow up your motor, so just do your homework and stay safe.
Old Jun 16, 2008 | 07:05 PM
white86vette
Cruising
thanks guys!!! I really appreciate the help!!!!
To nitrous question!!!!
