Engine starts then stops
It started with a rough idle, sometimes surging, but driving, it ran fine. I noticed my chrome exhaust tips were getting black, never happened before.
Two days ago, while driving on th NJTP at 65 - 70, it ran good for the first 30 miles, than it started to run rough, and eventually died. I could start it, it would run for a second or two then stop. Now that's all it will do.
Checked the fuel pressure with key on, 45 psi and it will hold. Pulled the vacuum line off the pressure regulator and no gas comes out. No codes in the ECM other than 12.
What should I ckeck next? Any and all help would be greatly apperciated. Thanks.
If the resistance is all over the place its probably a big clue that they may be defective. But also just because it measures correct doesn’t mean its not leaking either.
See where that goes in your troubleshooting effort, my only other thought is a flaky ECM but only a guess.
Check these threads started by FICINJECTORS
http://forums.corvetteforum.com/show....php?t=2055839
http://forums.corvetteforum.com/show....php?t=2055067
Jon is very helpful if you need injectors.
