'90 Vette Won't Run
Old Jun 17, 2008 | 11:45 PM
Larryrice's Avatar
Larryrice
Default '90 Vette Won't Run
My '90 coupe (L98 engine) won't run. I replaced the cap, rotor, center brush (the old one was broke). I replaced the fuel pump and filter. The computer only shows trouble code #32 relating to the EGR system. I checked the coil, I only showed open circuits, but the parts store checked it, said it was good. I am suspicious about this. I get spark some of the time only. I also get occasional firing in the exhaust system only. PLEASE HELP!
Old Jun 18, 2008 | 12:04 AM
jfb's Avatar
jfb
The primary of the spark coil will be low (0.5 ohms) resistance, but the secondary is moderate (6500 ohms) and constant. Use your timing light to see if you have reliable spark and spark at the right time while cranking. Pull a plug wire and bring a grounded wire near the plug wire while cranking, you should see a bright snappy spark easily 1/2 inch long. Measure the resistance of each plug wire, they should be about 5000 ohms per foot. At night with hood lights off, while cranking, look for sparks along each plug wire. Plug wires must not touch metal, check your wire looms and replace broken missing ones. A stuck open EGR valve will make for hard starting.
Old Jun 18, 2008 | 10:26 AM
Larryrice's Avatar
Larryrice
Thanks for the advice. I cannot get the timing light to work consistently. Maybe the coil has a broken wire, causing it to read normal at one time, open at other times. O'Reilly Auto Parts has a cheap coil for $14.95. I think I will try one. The EGR valve was disconnected before the engine failed, so it should not be a factor. I will check the plug wires also.
Old Jun 18, 2008 | 09:07 PM
jfb's Avatar
jfb
I don't know if 90's have a distributor or optispark, but the spark control module is also suspect and not expensive, consider replacing it too.
Old Jun 18, 2008 | 11:21 PM
PurtyLilC4's Avatar
PurtyLilC4
HEI distributors through 1991, opti started in 92.
I would definitely check into the ignition module
Old Jun 24, 2008 | 05:36 PM
blck90vette's Avatar
blck90vette
my 1990 wouldn`t run either,,would crank as if it wanted too...was going crazy finally changed out all injectors,,car runs like a champ now,,not saying this is your problem,,but maybe take a resistance test of your injectors. i would call JON at fuel injector connection...1-770-888-1662 and pick his brain,,very smart guy,and great customer service,,,calls you back every time to make sure your up and running,,,i believe i paid something like $190 for 8 bosch injectors 22#,,,like to hear the outcome to your problem,,so keep posting,,,good luck
Old Jun 25, 2008 | 08:42 AM
Larryrice's Avatar
Larryrice
Update: I have now replaced the pickup coil, main coil, rotor, cap, module in the distributor. I had a trouble code #32, but it erased itself. I also noticed the radiator fan running (with the a/c in the off position) with a cold engine-of course it is cold-it won't run.
I still get very limited spark or no spark. The engine tries to start, but that's all. The battery is strong. The timing light won't flash.
The ECM obviously has problems, but can it keep the ignition from firing?
Old Jun 25, 2008 | 08:54 AM
81c3's Avatar
81c3
Old Jun 28, 2008 | 10:37 PM
Larryrice's Avatar
Larryrice
I replaced the ignition module, and had it tested by the auto store. I will hot wire the 12 volt connection from the battery directly to the distributor. I will check into the injectors-from the help and suggestions, I suspect them now.
Old Jun 30, 2008 | 08:46 PM
Larryrice's Avatar
Larryrice
Thanks to all of you for your suggestions. I found the problem-the fuel injectors. I have two that are almost shorted, drawing excess electric power. This has caused my ECM to react and keep the car from running.
Old Jul 3, 2008 | 07:13 AM
blck90vette
change out all of them...call Jon at FIC
Old Jul 3, 2008 | 10:56 AM
Theking's Avatar
Theking
8th Gear
Go with the Bosch III 22lbs injectors from Fuel injector connection.
Call or email Jon at
Phone : 770-888-1662
Email : info@fuelinjectorconnection.com
Hes a really good guy and he will help you out with the injectors.
They bosch III cost 169,69 and they are modified to fit directly into your fuelrail. and they have 3 year warranty. couldnt get any better injectors then those
Old Jul 3, 2008 | 11:02 AM
schrade's Avatar
schrade
Your 32 code is a vacuum leak - betcha'....
You HAVE TO fix that. It doesn't 'go away'.
Old Jan 30, 2011 | 07:21 PM
ped299's Avatar
ped299
7th Gear
Default vats
dsabel vats that happen to me also.
Old Jan 30, 2011 | 08:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Vats will disable the start relay and it shouldn't engage the starter.
Old Jan 30, 2011 | 08:49 PM
engle1147's Avatar
engle1147
Why respond to a 3 year old thread?
Old Jan 30, 2011 | 09:12 PM
vetteoz's Avatar
vetteoz
Slow day?
Old Jan 30, 2011 | 09:41 PM
RLDaily's Avatar
RLDaily
I wonder if it started yet?
To '90 Vette Won't Run
