Transmission Temp Gauge
Old Jun 27, 2008 | 03:04 PM
Lichen's Avatar
Lichen
Default Transmission Temp Gauge
I would like to install a trans temp gauge in my '93 A4. I'm a bit confused by electrical vs. mechanical. Which would you guys recommend? I will probably mount it in a pillar pod, but then where should I connect the sending unit? Anybody done this?
Old Jun 27, 2008 | 04:10 PM
Aardwolf's Avatar
Aardwolf
I used an electric sender type, mounted in the pan. I used a trans pan drain plug kit and left out the plug then screwed in the sender. Couldn't be easier! I drilled a hole in the front drivers side of the pan, check very carefully where you put the sender as there is not a lot of room.
Old Jun 27, 2008 | 04:58 PM
Lichen's Avatar
Lichen
Do you remember where you bought the drain plug kit?
Old Jun 27, 2008 | 05:10 PM
Aardwolf's Avatar
Aardwolf
Summit or Jegs when I ordered something else. A local place would have them too.
Old Jun 27, 2008 | 05:54 PM
carlos85vette's Avatar
carlos85vette
Default Trans temp gauge
What I did was buy a extra oil temp sensor for the engine, and found a socket fitting that the sensor would fit into.Weld it into the trans pan, get a switch that can select between the 2 sensors, connect the original wire from the sensor to the switch and one terminal will go to old sensor and the other will go to the new trans pan sensor, then you can use your stock gauge and select between one or the other when needed.
To Transmission Temp Gauge
