L-98 Intake ?
Old Jun 29, 2008 | 07:13 PM
js292's Avatar
js292
Default L-98 Intake ?
Can some one tell me where these two sen's go?
And does anything go in this empty boss;
Old Jun 29, 2008 | 07:49 PM
adi4's Avatar
adi4
The 2 sensors are 9 injector switch ( larger one ) and ECU temp sensor (smaller one ) they go in the front of the manifold.
the hole in the manifold is a water blead hole.
Old Jun 29, 2008 | 11:59 PM
airdeano's Avatar
airdeano
the empty boss is the EGR temperatue diagnostics sensor. the block off
is for the EGR inlet from the exhaust header.
airdeano
Old Jun 30, 2008 | 12:50 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 there is a metal line that runs from a "T" in the top heater hose into that hole.
Old Jun 30, 2008 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes, a 1/8 NPT tap
Old Jun 30, 2008 | 10:28 AM
js292's Avatar
js292
thanks guys, so since I'm not using the egr I can just plug that hole right?
Old Jun 30, 2008 | 10:47 AM
Corvette Chris's Avatar
Corvette Chris
Using an EGR block off plate, yes.
Old Jun 30, 2008 | 11:36 AM
js292's Avatar
js292
thanks
Old Jul 1, 2008 | 01:11 AM
staugur's Avatar
staugur
Thats a water passage and nothing to do with the EGR.I'm not sure you will get proper circulation if you block it off.I believe it should connect into one of the heater hoses.
Old Jul 1, 2008 | 03:38 AM
rodj's Avatar
rodj
Had mine plugged for 5 years no probs.
I don't know what made the Vettes so special they need a vent; none of the aftermarket manifolds have a rear crossover.
Old Jul 1, 2008 | 09:15 AM
Calderone's Avatar
Calderone
that water hose on mine its blocked too....no problems at all
Old Jul 1, 2008 | 11:12 AM
js292's Avatar
js292
Thanks for all your help guys, when I saw the one pic of the hose connected to the manifold I couldn't remember my car having a hose like that at all. So I went and pulled the stock manifold out and it doesn't have that boss or the port for the block off plate I installed. So it looks like there are some differences in the early manifolds.(mine being a 85)
Old Jul 1, 2008 | 06:43 PM
staugur's Avatar
staugur
Just thought I'd throw in my 5 cents worth.............did you notice???
Old Jul 1, 2008 | 07:09 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Mine is plugged too.....
Old Jul 1, 2008 | 07:47 PM
js292's Avatar
js292
that's got to be the best use of a nickle I've seen in awhile
Old Jul 4, 2008 | 11:53 AM
js292's Avatar
js292
Here's another I need to verify before I screw it up. Am I putting the presure block on right? It's a super tight fit to the fuel rail, I've stripped the powder coating off the nipple and it seems like it will go on but I don't want to force it if this isn't correct/
Old Jul 4, 2008 | 12:56 PM
js292's Avatar
js292
OK, got it figured out. the powder coating was interfering with it. Got another question though, anyone know where the little "L" bracket/tab that sitting between the rails goes or what it goes too?
To L-98 Intake ?
Old Jul 4, 2008 | 08:27 PM
Bad Karma's Avatar
Bad Karma
I'm pretty sure it's in there to circulate the collant and get any trapped air out.
Old Jul 4, 2008 | 09:45 PM
js292's Avatar
js292
Actually this is a aftermarket manifold, and my stock manifold did not have that boss.
Old Jul 4, 2008 | 11:25 PM
John A. Marker's Avatar
John A. Marker
The 85 did not have this hole. They used it for 86 and up. It had a tube that connected to the heater hoses.
