Help with Bias Spring
http://forums.corvetteforum.com/show....php?t=1532610
With all the bias springs being installed and some of the stories of parts flying I have read I have decided to document this information so as to help others. I decided to do a test run on my spare master to figure out how I was going to do and what tools were going to work best when my spring arrived.
Hear is how I did it;
- Follow DRM instructions. This is additional info to get the spring in the valve
- Remove master from car and end nut that holds valve in and small tapered spring.
- Strike master on end to remove valve from master, (use wood). Remove O-ring and metal spacer.
- Record all configurations of parts removed.
- Take a 19mm deep socket and place in vice vertically.
- Wrap the valve in a paper towel to protect it and slip into socket so C clip is up.
- Take snap ring pliers and remove C-clip and spring.
- Drop new spring in valve.
- Get a straight blade screwdriver wide enough to depress spring into valve.
- Place C-clip thru screwdriver and grab clip with snap ring pliers and place screwdriver onto spring.
- Press spring with screwdriver down into cylinder, lower C-clip with pliers and snap in.
If you mess up, you wont loose the C clip. Getting it in the first time is easy.
- lube piston valve and re-assemble master in proper order.
- Bench bleed master and install back in car.
- Bleed master at fittings and or system.
Just a suggestion,
Jonathan
