CFI I need help
Old Jun 30, 2008 | 06:15 PM
stick105's Avatar
stick105
Default CFI I need help
I am replacing the IAC's on my 84 and noticed the replacment ac/delco IAC's didn't come with replacement gaskets, but the fsm says to replace the gasket with a new one supplied with the new motors. The Corvette supply I got them froom never called me back to tell me if I needed to use them. I assume I do need them. Can I reuse the old gaskets?
Old Jun 30, 2008 | 07:07 PM
MK 82's Avatar
MK 82
CFI-EFI hasn't been on in awhile.
Old Jun 30, 2008 | 07:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Re-use the old gaskets, or cut some new ones from sheet gasket.
Old Jun 30, 2008 | 09:39 PM
stick105's Avatar
stick105
thanks guys I will probally reuse the old gaskets.
I probally should use some gasket material though.
Old Jul 1, 2008 | 09:42 AM
NEVRL8T's Avatar
NEVRL8T
He is logging on. He just isn't posting.
Old Jul 1, 2008 | 09:58 AM
80sRule's Avatar
80sRule
I bought a new one(NAPA) a while back and it didn't come with a gasket either. I had to do some paper cutting as you said.
Old Jul 1, 2008 | 02:07 PM
stick105's Avatar
stick105
I just installed the new motors and luckaly the old gaskets were stuck to the throttle bodies (phew). Car runs great after blowing all the carbon out of it!
To CFI I need help
