U-Joint Opinion
Old Jul 2, 2008 | 11:57 PM
Chapindad's Avatar
Chapindad
Default U-Joint Opinion
I am going to replace my rear axle u-joints. Are the ones at Ecklers good to use or does someone have a better place to purchase it?
Old Jul 3, 2008 | 02:06 AM
jcb5565's Avatar
jcb5565
Go to Napa Auto parts cheaper and better.
Old Jul 3, 2008 | 02:45 AM
racebum's Avatar
racebum
if you enjoy working on your car a lot, do use napa or ecklers. in my opinion those joints are complete garbage. the only off brand that auto parts stores carry that is even remotely decent is naepco. buy spicer, they don't cost more and they are FAR stronger. those cheap ones will liquidate the needle bearings really quick, overheat and snap. tolerances are just crap. yes i have broken more than one precesion brand. not only are they trash but they are hard to install. why you might ask, well, the tolerances ! they suck, seriously if someone offered to kick me in the junk or force me to run cheap joints i would actually need a minute to think about it.
Old Jul 3, 2008 | 04:17 AM
rodj's Avatar
rodj
Got to think outside the square. Not all Vette parts have to come from Ecklers.
Go to a place that builds driveshafts or sells truck parts.
And buy Spicer 1350 uni's.
Old Jul 3, 2008 | 06:53 AM
Sawbone's Avatar
Sawbone
I replaced mine with Spicer's after doing a lot of research on the forum and definitely recommend them. I got mine from Tom's differentials http://www.tomsdifferentials.com/
Old Jul 3, 2008 | 09:43 AM
WW7's Avatar
WW7
Thepartsladi has GM AC Delco originals for $70.00 for the complete set of 6. This is hard to beat...WW
Old Jul 3, 2008 | 12:27 PM
IBVETN2's Avatar
IBVETN2
I replaced mine with Neapco Brute Force. price and quality are equal to spicer and they are easier to find. Mine see only hard use from autocrossing and no problems.
Old Jul 3, 2008 | 02:04 PM
DVNCI's Avatar
DVNCI
I bought my Spicer's from these guys a while back:
http://www.drivetrainspecialists.com/
Great service
Old Jul 3, 2008 | 02:38 PM
racebum's Avatar
racebum
OE is dana which is spicer
Old Jul 3, 2008 | 02:39 PM
vader86's Avatar
vader86
Get spicer only.
Old Jul 3, 2008 | 03:21 PM
jrp's Avatar
jrp
Can't find any at the moment, but I thought I had read several threads last year indicating that the appropriate Spicer ujoints are no longer made or were superceeded by the parts which aren't (as) suitable for aluminum shafts. Confirmation, anyone?
Old Jul 3, 2008 | 03:24 PM
zeitgeist57's Avatar
zeitgeist57
I've gotten a wheel bearing from Thepartsladi on eBay and it's held up well over the past 4 years. I never thought about it, but I guess the stuff she sells is legit!*
*only reason I question it is that there have been "genuine AC Delco" sellers on eBay before that scam the shozz out of you with cheap ***** parts.
Old Jul 3, 2008 | 05:00 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by vader86
Get spicer only.
+1 for spicer (sealed)
I bought mine from a local driveline shop.
Old Jul 3, 2008 | 05:02 PM
racebum's Avatar
racebum
sure are, you should see the designer clothing market on ebay. many of the high end jeans are all knock offs. people are trying to push $10 china jeans that kinda sorta look like diesel or rock & republic etc as the real product. it's a felony doing so but no one seems to get busted. back to the joints, how could you not be able to find spicer? one of the posters gave you a link to a site that sells them? also you can google six states trucking & order from them. as to the "right cap" that non rust stuff was hokey. when is the last time you noticed aluminum rusting? the steel can but it's 99.9% sealed by the aluminum around it. dana quit producing those for a reason. they didn't do anything. one of the guys at six states actually called dana about that when a c4 owner made a fuss. one of the techs at dana said the same thing. they were stopped for a reason, no benefit. just get a 1350, standard or the stronger non greese. think about how long the OE spicers lasted you, dontcha wanna replicate it?
Old Jul 3, 2008 | 05:54 PM
jrp's Avatar
jrp
I won't dispute Dana's conclusion, but will dispute the reasoning.
- Aluminum may not rust, but it does corrode, which is why anodizing & conversion coatings exist.
- Galvanic corrosion from the dissimilar metals is an issue in this application. The steel is sealed by the aluminum around it? Tell that to the bolts that get slathered up with anti-sieze before getting threaded into our heads or the brake rotors that people fight to remove from their hubs.
No benefit? I don't buy it. Not enough benefit to justify maintaining a product line for a dwindling market? That is more likely, and in the end it may well be an acceptable trade for us.
Old Jul 3, 2008 | 05:58 PM
TA's Avatar
TA
Got my Spicers there also
Old Jul 3, 2008 | 10:25 PM
newbecorvetteguy's Avatar
newbecorvetteguy
That's where I got mine. Two years and counting @ 60 miles per day. Seem good enough to me so far.
To U-Joint Opinion
Old Jul 4, 2008 | 02:05 AM
racebum's Avatar
racebum
could be? i have no idea how it will go over the years. i do know that pulling a 2yr old joint is no big deal. 12yrs....might be different. at any rate dana is in trouble & GM is trading at levels it hasn't seen since the 50s. we're kinda stuck.. your arguement with the bolt makes sense. i guess we just bash the u joing with a bigger hammer or press when we need to remove a really old non coated one.
Old Jul 4, 2008 | 07:47 AM
89er's Avatar
89er
Thepartsladi's so called OEM Delco U-joints for $70 were never OEM on the Corvette.
They do not have the anti-corrosive coating needed for aluminum driveshafts. I got a refund on mine minus two-way shipping and had to fight to keep from paying a restocking fee.
Old Jul 4, 2008 | 08:03 AM
BlackHarleyMan's Avatar
BlackHarleyMan
I chose these as an option TO the spicers, these came highly recommended.
Noland
