Trans ?
Old Jul 3, 2008 | 10:34 PM
pipe's Avatar
pipe
Default Trans ?
Is the Auto Trans in my 84 the same as my 88? And if I swap em over will everything fit? THANKS Pipe
Old Jul 3, 2008 | 11:16 PM
JackDidley's Avatar
JackDidley
The torque convertor has to stay with the original trans. They changed the splines in 86 or 7 I think. The newer trans got better guts also.
Old Jul 4, 2008 | 12:21 AM
hexane's Avatar
hexane
The pre-87 700R4s had 27 splines on the input shaft. They were less reliable than the newer ones. The newer ones had a 30 spline shaft and were of a much better design. Both could be built up to stand extra power. I would go with the new design as there seems to be much more support for it than the older design.
Old Jul 4, 2008 | 06:33 AM
PBA's Avatar
PBA
The 1988 is a much better unit to start with, and has many updates that are not in the 1984 unit. In mid 1984 they went from 27 to 30 spline. Go from there.
Old Jul 4, 2008 | 11:47 AM
pipe's Avatar
pipe
Thanks Guy's actually i'm converting a manual trans car over to an auto. Pipe
To Trans ?
