Brake fluid flush
Old Jul 7, 2008 | 03:14 PM
OBSESHON Mark's Avatar
OBSESHON Mark
Default Brake fluid flush
I tried the search feature but nothing came up.
I have a 1990 Vert. What is the best way to do a brake fluid flush?
Thank you in advance for any ideas.
Mark.
Old Jul 7, 2008 | 04:11 PM
MK 82's Avatar
MK 82
Here is what I use. Motive Products Power Bleeder. Simple one-man job.
http://www.motiveproducts.com/index.html
Old Jul 7, 2008 | 04:37 PM
aklim's Avatar
aklim
I empty out the reservoirs and remove them for cleaning. After that, I fill them up. Crack the bleeder open and do the "Open, down, close, up" routine with the wife.
Old Jul 7, 2008 | 05:54 PM
pianoguy's Avatar
pianoguy
I installed SpeedBleeders when I did mine this spring, worked like a charm. I also bought their little reusable plastic bag with the hose attached, which made it a much less messy job.
aklim's Avatar
aklim
Not that bad of a mess. You can wash it away with a little hose action
Old Jul 7, 2008 | 08:08 PM
NC94Vette's Avatar
NC94Vette
I use the same thing. Not much pressure is needed. Around 8 to 10 pounds. Works slick.
Old Jul 7, 2008 | 08:36 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I use a Mityvac. It comes in handy for vacuum testing too.
http://www.mityvac.com/pages/products_hvpo.asp
Old Jul 7, 2008 | 10:24 PM
Lichen's Avatar
Lichen
No brainer. SPEEDBLEEDERS!!!!!!!
Old Jul 7, 2008 | 10:31 PM
jrp's Avatar
jrp
Speedbleeders make it a one man job, but...
Originally Posted by jrp
I had my wife pump the pedal anyway. I watched at the caliper and held a sheet of paper behind the tube. The new fluid came pretty quickly, but there was still dirty stuff passing by in small amounts after 10-15 pumps. Overkill? Maybe, but it was interesting to note.
The paper made it very easy to see when the clean fluid came through.
Old Jul 7, 2008 | 10:33 PM
aklim's Avatar
aklim
I usually run it thru a clear tube which makes it easier to see.
Old Jul 7, 2008 | 10:52 PM
Lichen's Avatar
Lichen
You're avatar is so hot that I find it hard to argue with you.
Old Jul 7, 2008 | 11:06 PM
jrp's Avatar
jrp
Let me clarify. The tube was clear and dirty fluid was much, much easier to see with the paper as a backdrop vs. a dingy garage floor.
Old Jul 7, 2008 | 11:23 PM
OBSESHON Mark
Thanks for all the great info guys.
Guess what I will be doing tomorrow
Old Jul 8, 2008 | 08:27 AM
runner140*'s Avatar
runner140*
Old Jul 8, 2008 | 11:33 AM
janarvae's Avatar
janarvae
1 more for SpeedBleeders. If you go that route get the authentic ones on the official website.
The mityvac is good too and can be used on multiple cars with reservoir adapters.
To Brake fluid flush
