86 Low Coolant Level
I replaced the leaking OEM water pump with a nice Edelbrock over a year ago.
Q1: Anyone know where the level switch is located, and how to replace?
Q2: I have no visible coolant leaks. Where do I start to look?
Jack
I'd be checking the area between the radiator and the condensor for debris....our C4s suck up all kinds of crap.
2. In your oil. What does the under side of the oil fill cap look like?
That said, you could have other problems as noted.
I checked my oil and oil cap. Both are pristine. The engine runs fine with no sign of a blown head gasket, thank God!
I found my low coolant level sensor located about 6" below the rediator pressure cap on the passenger side. I suspect that my coolant level may not have fallen below that level as the radiator took a 1/2 gallon of coolant and the surge tank took the other half that I added.
My shop manual recommends checking the coolant level in the surge tank every time you open the hood. That's good advice, that I failed to heed.
My dash display flashed red briefly when the temperture reached 260. As soon as I started rolling the temperture rapidly cooled to the normal 180 with outside air at 100.
Q3: My AC doesn't seem to be putting out sufficient cooling. I've never had it serviced. The car has only 40K miles. Shop manual calls for R12 refrigerant Man, I'd hate to go thru that nasty upgrade. Did that in my Suburban and the cooling sucked due to lower efficiency.
Jack
To my shock and amazement, the coolant sensor is a little blade of metal encased in a plastic shell.
No "sensor", no electric device, just a little piece of metal molded in a plastic shell.
Unless you have taken it out, don't touch it.
Here's what you need to know:
The water grounds the blade to the block because the water is conductive, and the transistor that controls the light needs the ground to shut off the flow of electricity to the light that says "low coolant".
When you lose that ground, the transistor turns on the power to the light, and you know you need antifreeze.
If you don't get the low coolant light, I suggest that you clean the grounds on the head at the back of the engine, and clean the other end on the frame.
If you still do not get a low coolant light, I would suggest that you check the light bulb on the driver info panel, the previous owner might have driven years with that on and burned out the bulb.
or the bulb socket might have some anomaly.
Good Luck!
