Start Enable Relay
Old Jul 9, 2008 | 07:40 PM
ZQQM's Avatar
ZQQM
Default Start Enable Relay
Need your help locating the start enable relay for my 1991 rag top. I need to disable the Vats.
ZQQM
Old Jul 9, 2008 | 07:52 PM
engle1147's Avatar
engle1147
It's just above/behind the radio in my '89.....it may differ on your year but I doubt it...I'm sure someone else will chime in to confirm the exact location for your year model.
Good Luck!
Old Jul 9, 2008 | 11:26 PM
92LRC's Avatar
92LRC
ZQQM
Go on this site for all VATS info
http://www.vatssucks.com/
Old Jul 10, 2008 | 01:39 PM
gw962's Avatar
gw962
It may be similar to my '90. Remove the insulator panel under the steering column and the metal knee bolster under the insulator.
As you look up to the left of the column, you should see two relays. Look for the one with the thick yellow and yellow/black wires coming out of the back. That should be it. The relay next to it is for the A/C.
To Start Enable Relay
