where does this go?
Old Jul 9, 2008 | 09:58 PM
BONNOUGHJ's Avatar
BONNOUGHJ
Default where does this go?
I was looking over the motor today, and I noticed that there was a wire with a plug on it that was plugged into any thing.. Where should it go?
THANK YOU
JEREMY
Old Jul 9, 2008 | 10:40 PM
BONNOUGHJ's Avatar
BONNOUGHJ
ok,, I fixed the photos. You should be able to see them now.
THANKS
JEREMY
Old Jul 9, 2008 | 11:13 PM
pianoguy's Avatar
pianoguy
If I'm looking at the right wire, it goes to a sensor of some sort on the master cylinder (maybe brake fluid level monitor?), just below the brake line fittings.
Old Jul 9, 2008 | 11:14 PM
81c3's Avatar
81c3
Should be a sensor on the brake master that it plugs into.
Old Jul 10, 2008 | 08:40 AM
BONNOUGHJ's Avatar
BONNOUGHJ
I'll look again, but I think that there is anther wire coming out of the same harness that allready goes to the master cylinder. I was looking at it.
JEREMY
Old Jul 10, 2008 | 02:28 PM
pcolt94's Avatar
pcolt94
Two connectors go the master. One for the low fluid sensing, and the other for the proportion valve. It senses the valve has not moved to one side indicating some sort or hydraulic failure in one of the brake systems. It goes low on the master where the indicator switch screws into the metal base of master.
Old Jul 10, 2008 | 02:31 PM
BONNOUGHJ's Avatar
BONNOUGHJ
Thanks.. I'll take a look at that..
JEREMY
To where does this go?
