tpi question
Old Jul 17, 2008 | 03:23 AM
twotonethunder's Avatar
twotonethunder
Default tpi question
after a quick search on tpi conversions i found out that the camaro tpi setup is different then the corvette setup
but what i couldnt find is whats actully different is it just the wire harness wont match up to our cars? or just because the computer has a different tune in it? or what am i missing? theres 87 Iroc with a tpi sitting in the local junkyard and if i can make this work id love to ditch my crossfire injection in a second
Old Jul 17, 2008 | 03:31 AM
schrade's Avatar
schrade
TPI would be a good thing to do. They have as much torque as LT1, without the need for premium gas.
The parts you can probably get dirt cheap, but you will have to do some researchin tho'...
Old Jul 17, 2008 | 04:10 AM
ZD1's Avatar
ZD1
The TPI is very similiar accross the camaro, corvette. The main difference is the year. You'll want to check for a 9th injection in that IROC setup. Also, before you buy consider getting the edelbrock TPI base and runners as the CFI may actually have more flow potential.
You'll need an aftermarket computer setup (8 + 1 injectors vice the TWO you have right now
Best bet for a bolt in is for the "X ram" that I vaguely remember the cross-fire guys talking about. Other than that, everything ($2500-4500 must be replaced.
If you are down on power you may just need a good cleaing for the intake, injectors, vacuum lines, etc...
Old Jul 17, 2008 | 04:39 AM
Demonic85's Avatar
Demonic85
The difference between the F-body TPI and the Corvette TPI is the fuel rails are different. The Inlet/Outlet is on the driver's side for the F-body, corvette is on the passenger side. Other than that yes the years are different. '85-'88 all have the 9nth injector, '90-'91 have a provision for the MAP sensor.
Old Jul 17, 2008 | 06:07 AM
conv90's Avatar
conv90
this link helped me alot:
http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf
-Beppe-
Old Jul 17, 2008 | 09:42 PM
twotonethunder
thanks for clearing that up
as for the aftermarker computer the iroc computer wouldnt work?
Old Jul 17, 2008 | 11:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There may be issues with your digi-dash interface??
Old Jul 17, 2008 | 11:55 PM
twotonethunder
my dash is all messed up and not working properly anyway im interested in creating a custom dash with autometer guages and deleting the message module in the center of the dash and placing something else there
To tpi question
