Weatherstrip replacement..how do questions...help!
I just bough the A-pillar/roof header piece from Wilcox, and have removed the original weatherstripping. Came off really easy in once piece. Here's where the questions start:
1.) what is the best way to get all the crud off? I've started with an exacto knife with a chisel blade. Is there a quicker way? When it comes to getting the old glue off, how much of it do you actually get off? How will I know I've gotton enough off? How long does it realisticly take? I was hoping this could be a 3-4 hour job. Am I way off here thinking that? I haven't driven my 'vette in days and I am not going through some withdrawl over it...ahhh!!!
2.) Do you remove the flanges where the glue is? I am scared I might bend them trying to pry them off. I took all the screws out of the A-pillar and that metal flange won't budge.
3.) I bought the black 3M weatherstrip glue from Wilcox. Comes in a black tube with red lettering. There are no instructions of any kind on the back. What is the drying time?
4.) How EXACTLY is the glue applied? I've heard you're supposed to put a bead on the weatherstrip and smear it and on the part of the car it touches and let it dry completely...I guess to make a rough surface for the glue to bond to.
5.) and obvious no no's?
Bottom line, I just want this to be a one time job. I don't wana do a crappy job and have to redo it-I wana get it right the first time.
you do not need to remove anything besides the weather stripping. The tack puller fits in those channels perfectly. I did not get real **** about scratching the channels on the inside. The adhesive and strip will keep them dry.Even if you screw up new weatherstripping is a lot easier to remove without damaging it. I got a bad piece and removed it without hurting it( I did not remove the mold release from the strip though).
Here are some tips on how to install weatherstrips correctly. While it will not deal directly with the C4 the method is the same.
http://willcoxcorvette.com/repairand...lp.php?hID=160
1.) The ONLY way is to use a WS adhesive solvent; I got a quart can of the 3M solvent at a local AC Delco dealer. The most tedious part and most important part (IMO) of the job is removing every trace of the old adhesive.
2.) Sorry but I don't recall removing any flanges in any area.
3.) I laid a strip of glue into the channels and then simply pressed in the WS piece, using popsicle sticks to avoid tearing the WS. I used a sort of zig-zag pattern of adhesive in the track.
4.) On the positive side, test fit the WS into the channel before applying the adhesive. Then remove and apply adhesive. Once the WS in installed, button her up and walk away for a day or so. Also, pick a sunny warm or even hot day to do the installation and let the WS heat up in the sun before installation.
I laid the A-pillar WS over the top, applied the adhesive into the side tracks, installed the WS into said tracks, applied the adhesive into the header track then installed the WS into the header track, beginning in the center and working to the sides.
It was the first time to do any WS installation and the job came out perfect, it just took a long time to do the prep work.
You do not NEED to use any glue on the weatherstrip. Most people do in fact use glue, but several of us have done it without glue successfully. At the corners I used 3M bedding and glazing compound. I then installed the weatherstrip, mostly for a test fit without any glue and left it that way, no leaks.
http://forums.corvetteforum.com/show....php?t=2023336
http://forums.corvetteforum.com/show....php?t=2027495
lots of experience there.
Took a few evenings to do.
