Need another measurement please!!
Old Jul 19, 2008 | 11:51 PM
Devilbrad's Avatar
Devilbrad
Default Need another measurement please!!
OK, I asked about the front LCA's, now I need to know the height from the ground to the rear LCA inner pivot bolt with vehicle on ground and loaded. Also, the rear lateral links (I'm a Mazda tech, thats what we call them, LOL), what is the angle between their front pivot bolts in relation to rocker panel (or ground) and is the lower parallel to ground or inclined? I know how far apart they are, have their bracket, just need to know the mounting angle. Can anyone help?
Old Jul 20, 2008 | 02:04 AM
schrade's Avatar
schrade
What year?
I think there's probably a little variation from '84 - '96...
Old Jul 20, 2008 | 03:02 AM
Devilbrad's Avatar
Devilbrad
Originally Posted by schrade
What year?
The suspension I have is from a '96, going in an old Dodge truck. Thanks!
Old Jul 20, 2008 | 06:16 PM
Devilbrad's Avatar
Devilbrad
Can anyone help?? Thanks.
Old Jul 20, 2008 | 06:54 PM
schrade's Avatar
schrade
What are your tolerances?
Even if someone can measure their own for ya', you might not be able to rely on their measurements. Are these specs even in the FSM?
Old Jul 20, 2008 | 07:01 PM
Devilbrad's Avatar
Devilbrad
I'm trying to keep the stock Corvette geometry. By knowing the lower inner rear control arm pivot bolt location from ground, lower lateral link front pivot height from ground, and center of tire height (I believe the C4's use 26" tall tires, so 13" at the center of hub), everything else will fall into position. I just have to modify my frame for the ride height I want. I would feel weird crawling around under a Corvette in a random parking lot, ha ha.
Old Jul 20, 2008 | 07:30 PM
schrade's Avatar
schrade
Is this what you're lookin' for? It's a '94...
6". Give or take about 3/16ths, it's gotta' be close to spec.
Old Jul 20, 2008 | 07:37 PM
Devilbrad's Avatar
Devilbrad
I almost owed you some beer! I actually need the inner pivot measurement.
Old Jul 20, 2008 | 07:38 PM
schrade's Avatar
schrade
You mean the one at the diff?
Old Jul 20, 2008 | 07:44 PM
Devilbrad's Avatar
Devilbrad
Yes sir!
Old Jul 20, 2008 | 08:10 PM
schrade's Avatar
schrade
Looks like 8".
Old Jul 20, 2008 | 08:14 PM
Devilbrad's Avatar
Devilbrad
Looks like 8".
That is close enough!! PM me your address, you have a gift certificate for a case of beer of your choice on its way!!!
Old Jul 20, 2008 | 08:17 PM
schrade's Avatar
schrade
I'm fine.
You help, you get helped.
Pass it on.
Old Jul 20, 2008 | 08:22 PM
Devilbrad's Avatar
Devilbrad
I'm fine.
Pass it on.
Thats my attitude. Thank you.
Old Jul 20, 2008 | 09:09 PM
grinditout's Avatar
grinditout
Old Jul 20, 2008 | 09:19 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Post a few pictures sometime.
I put the complete C4 suspension on my '51 Chevy pickup a while back. The '92 rear trackwidth is a touch too wide with the wheels I'm using, so I'll be putting in a set of '84-87 rear spindles/knuckles in the future to narrow the track an inch or two. Next step is to finish the recessed firewall and wiring issues. Looking forward to getting it on the road once I finish my '69 w/C4 suspension transplant currently in progress.
Old Jul 21, 2008 | 02:43 PM
Devilbrad's Avatar
Devilbrad
That looks good. Did you us the whole rear frame section from the Vette?
Old Jul 21, 2008 | 03:57 PM
69427's Avatar
69427
Not sure I understand your question. I put the C4 suspension on the original frame of the '51 truck in the picture, and also put a C4 suspension on the spare '69 frame (bottom two pictures) for my '69 Corvette.
To Need another measurement please!!
