Turn signal problem
Old Dec 29, 2001 | 11:50 PM
MattS4313's Avatar
MattS4313
Default Turn signal problem
when i turn on my lights, my right blinker arrow lights up. when ever i turn the right blinker on, nothing happens. any clues?
thanks
Matt
P.S. is the forum running real slow to you guys also?
Old Dec 29, 2001 | 11:54 PM
scorp508's Avatar
scorp508
Default Re: Turn signal problem (MattS4313)
Speed is fine here.
If the arrow lights up and stays lit (no blink), but the directional does nothing.... you have a blown bulb, or at least one of the fillaments in the bulb.
Check...
Front Turn Signal Bulb
Front Side Turn Signal Bulb
Both Right Taillamps.
The easiest way to check them is to turn the lights on, and then turn the hazards on. Walk around the car and see which one is just plain out, or not blinking. :)
Old Dec 30, 2001 | 12:03 AM
MattS4313's Avatar
MattS4313
Default Re: Turn signal problem (scorp508)
ok bear with me here....
i tested it, turned on the hazards and all the lights blink.
tried then to just turn on rights and nothing happend, tried turning on left and it works.
:cry :smash:
65Z01's Avatar
65Z01
Cruise-In II Veteran
If not a bulb check the front bulb socket and wiring.
Sometimes my right turn signal behaves the same way. Then I turn on the right turn signal with the ignition on, open the hood and wiggle the wire close to the socket till the turn signal flashes. Some day I need to trace it down and replace the socket or wiring.
Old Dec 30, 2001 | 12:06 AM
scorp508's Avatar
scorp508
I have the EXACT same problem with the EXACT same socket.
Old Dec 30, 2001 | 12:22 AM
MattS4313's Avatar
MattS4313
Default Re: (scorp508)
well, your guys are right, that was the problem. how do yall keep it staying though, i could hold it and it would work, but as soon as i would take my hand away it would stop. do you tape it? i messed with it for about 10 mins, but i know even if i did "jiggle" it into place it wouldnt last under driving conditions ;) ;)
Old Dec 30, 2001 | 12:30 AM
Romeo Barrera's Avatar
Romeo Barrera
Holy SH|T!!! It's funny you guys mention that, because MY right turn signal is lagged and sometimes doesn't blink. All lights blink with the hazards. If I wiggle the right front side marker light, they blink. Hmmmmmmmm, what did GM engineers screw up now?
No no........it's the Corvette Gods trying to tell us something. Everyone buy a lottery ticket this weekend ;)
[Modified by Romeo Barrera, 11:32 PM 12/29/2001]
Old Dec 30, 2001 | 03:15 AM
65Z01's Avatar
65Z01
Default Re: (MattS4313)
If I move the cable slowly I can get it to blink properly for a while. Though I recently had to stop twice on a 450mi trip from Richfield, OH to W.Nyack, NY to "readjust" it.
To Turn signal problem
