Need help with door key
Old Aug 1, 2008 | 03:52 PM
rwynn's Avatar
rwynn
Default Need help with door key
The driver side door does not recognize the key. I have replaced the sensor in the door, same problem. I have to unlock the door from the passenger side to turn off the alarm. Anyone know what the problem could be. Thanks
Old Aug 2, 2008 | 11:51 AM
C4boy's Avatar
C4boy
You replaced the 2 wire switch that sits behind the door lock? It's just a mechanical switch, so my guess would be a wiring problem from the lock switch forward. That's assuming the replacement switch is good and installed correctly.
Old Aug 4, 2008 | 09:46 AM
rwynn's Avatar
rwynn
Yes that's one I replaced. I will look into the wiring issue thanks.
To Need help with door key
