Having problems!!
Old Aug 4, 2008 | 11:43 AM
pearlvett's Avatar
pearlvett
Default Having problems!!
Ok so i need some help. Im really new to corvette and im doin some maintinance in my drive way just small stuff. I went to jack up the car to get to the fuel filter and i cant find a jack point anywhere! Someone please help me!
Old Aug 4, 2008 | 01:36 PM
GKK's Avatar
GKK
Look along the lower rocker panel. There are two arrow marks indicating the jacking points, one behind the front wheelwell and one in front of the rear wheelwell. Place the jack on the Pinch weld of the frame.
Also, if you look underneath the frame, you can see a couple flat spots that you can place the jack stands.
Another tip; you can place the jack on the pinch weld just behind where the side view mirror is and then you can lift both tires off the ground.
Old Aug 4, 2008 | 01:45 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Here are some photos of jacking points,
File Type: pdf
Old Aug 4, 2008 | 01:49 PM
pearlvett's Avatar
pearlvett
SWEET! Thanks alot!
Old Aug 4, 2008 | 01:55 PM
94z07fx3's Avatar
94z07fx3
A ramp turned backwards is better for the fuel filter than a jackstand because the stand will be right in your work area. I'll send you a PM with some tips that worked well for me on the fuel filter R&R.
To Having problems!!
