Buddys corvette ..help!
Old Aug 4, 2008 | 01:29 PM
tremere613's Avatar
tremere613
4th Gear
Default Buddys corvette ..help!
My friends corvette is a 1990 regular (with removable top )
anyways its got several problems to say the least...
if you can answer help me resolve any of these issues it would be greatly appreciated
1. the whole engine compartment is extremely hot!! (i know cars are suppose to run hot...but i dont think this engine is getting cooled period)
could it be cooling fluid needs to be replaced? radiator fluid?
2. brakes stop working after about an hours use.....(could it have to do with car over heating?) another thing i realized is that the pump is not sealed off completly i mean water could fall in (its kind of like a balloon with a stick in it but theirs no seal..if i were to clean the engine...water would def fall into the pump...is that normal?
3. air intake is cracked...could i seal with apoxy or silicone?
i cant find replacement anywhere (ecklers only has inlet tube)
i need the triangular piece of plastic that leads to airbox
4. their is some kind of small motor or pump that makes this loud noise when i accelerate/brake located right behind drivers side seat
anyone know why its sooo loud!! or what it is?
5. where can i find pumps for rear window(mine are rusted)....that window doesn't stay open....and the lock also seems to have some difficulty locking
6. thank you for reading!!!!!!!!!!!!!! any help greatly appreciated!!!
-Dan
Old Aug 4, 2008 | 03:46 PM
gw962's Avatar
gw962
These cars tend to run hot, supposedly to reduce emissions. Use a flashlight and look into the small port cut into the passenger side of the radiator housing. The front of the radiator may be full of junk. Clean this area out if it's dirty. It won't cool down the engine compartment much, but it will help the engine last longer.
I'm not sure from your desacription on the "pump". Can you post pictures?
You can probably find a replacement on auction sites, but epoxy will work also.
Your ABS pump is located in the compartment behind the drivers seat. It should only activate briefly for a self test at 4 mph. If it's running all the time, this may explain why you have no brakes. Wheel sensors or the pump itself may be bad.
Replacement cylinders are avaiable at auto parts stores.
-Dan
Hope this helps
Old Aug 4, 2008 | 03:58 PM
tremere613's Avatar
tremere613
4th Gear
cant find intake in any auction site!! if u have a link it would be greatly appreciated!
anyways i will post pics as soon as i take em!
THANKS!! gw962 for the help so far but more input would be greatly appreciated!
and also where can i buy this "ABS pump"?
Old Aug 4, 2008 | 05:14 PM
gw962's Avatar
gw962
I'll send you a PM with the links.
Old Aug 4, 2008 | 05:22 PM
tremere613's Avatar
tremere613
4th Gear
still need help with rest of problems!
Old Aug 4, 2008 | 05:32 PM
schrade's Avatar
schrade
You'd better edit/delete your post to ONE problem. It is already difficult with many people addressing ONE problem, much less SEVERAL problems. Trust me - NONE will get solved.
The first problem is heat. What does the temp gauge say?
Old Aug 4, 2008 | 07:14 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I never saw a regular Vette.
Old Aug 4, 2008 | 07:55 PM
TJBlaylock's Avatar
TJBlaylock
I can only help you with No. 5, if you look at some of the adds on the left you will be able to find the back window posts. Good luck with the rest.
Old Aug 5, 2008 | 01:00 PM
tremere613's Avatar
tremere613
4th Gear
lol pkazsr... regular meaning non-zr1......
gm didnt have the intake we actually went to dealer...they said they dont have a lot of 1990 parts....
and i dont know how hot...will the display tell me?
Old Aug 5, 2008 | 01:11 PM
schrade's Avatar
schrade
[ME]
To Buddys corvette ..help!
