Headlight Adjustment
Old Aug 5, 2008 | 12:57 PM
CAJUN C4's Avatar
CAJUN C4
Default Headlight Adjustment
What's the proper procedure for adjusting Headlights.
Mine are way too low.
Old Aug 6, 2008 | 10:03 AM
CAJUN C4's Avatar
CAJUN C4
Might be in my FSM.
Old Aug 6, 2008 | 12:13 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
What I do is ,at night, park about 30 ft from a wall or garage door and turn on the lights to see where they point.Around the edges of the head light are 2 screws(phillups) that adjust up and down and L/R positions. I then tweak them where I want a couple of turns and go around the block and repeat.
Old Aug 6, 2008 | 12:41 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your owner's manual, too.
Old Aug 7, 2008 | 11:17 AM
CAJUN C4's Avatar
CAJUN C4
The FSM has a procedure but you need to place some kind of headlight screen on your garage door. I don't know where to get one?
Old Aug 7, 2008 | 11:38 AM
Redeasysport
You do not need a screen just eyeball it. You will know if you get them too high by the people flashing their lights at you. It is not that hard just do it at night and test drive it.
Old Aug 7, 2008 | 01:07 PM
CAJUN C4's Avatar
CAJUN C4
Idea !
I'll park the 96' 10-15 ft. or so from my garage door and mark where the light shines at then I'll pull the 95' back at the exact same location and adjust to those points.
Sounds like a plan.
Old Aug 7, 2008 | 01:11 PM
Redeasysport
Whatever it is not rocket science.
Old Aug 7, 2008 | 02:13 PM
CAJUN C4's Avatar
CAJUN C4
No it's not. Just wanted input to make it a little easier
Thanx Readeasysport for your input.
And everyone else.
To Headlight Adjustment
