What can be programmed "OUT"
Old Aug 6, 2008 | 08:11 AM
TJM's Avatar
TJM
Default What can be programmed "OUT"
Bad news if you set a Code 32, you could be up the creek over a $16.00 part.
I tried to get a EGR diagnostic switch, the little gizmo that goes into the EGR riser tube.
None available. No longer stocked.
Can we program [or wire] the entire Pollution I/O out?
This thing changes state twice so it will be tough?
TJM
Old Aug 7, 2008 | 12:43 AM
Benny42's Avatar
Benny42
Try asking your parts store for the same part for a camaro. Its
got a longer wire and a different part number, but will work and
is usually stocked around here. Good luck. Benny
Old Aug 7, 2008 | 11:10 AM
TJM's Avatar
TJM
Tried it. Yukon, Impala, Firebird?
Any part that is used on 1989 but not later is out here.
I bought the two I found at The Last Detail.
The guy laughed at my conspiracy theory [ I am a bit paranoid] , but when he came back from asking Delco for replacements... the answer was NO Got. To bad So sad.!.
TJM
To What can be programmed "OUT"
