90 - starting / no starting problem
Old Aug 11, 2008 | 03:27 PM
mypantera's Avatar
mypantera
Default 90 - starting / no starting problem
Hi, I have a 1990, 106,000 miles, L98 (I think) with a 6 speed. The problem I am having is when it is hot out the car will not start. If we spray starting fluid down the plenum it will start right up and continue to run with the fluid and then stalls without the fluid. This happens when the engine itself is cold from sitting over night etc. go out on a cooler day and the car will start up and run with no problems at all. For example, the other morning, I needed to get by the car so I started it up and moved it about 20 feet. The car started right with no issues. Later on that same day, I tried to start it will no luck. One shot of starting fluid and it starts and runs until the fluid runs out. Obviously this is a fuel problem but I have no idea where to start. Yesturday, I started it up and took it for a ride again with no issues. Even when the engine is hot it starts right up. Seems to be only when it is very hot outside for some reason but that could be just a coincedence. Lastly, yes there is fuel in the tank. The gauge says 1/2 tank and I put in an extra 5 gallons just in case the gauge was wrong. Also all fuses look to be in good shape with none blown.....
thanks for your help!
Old Aug 11, 2008 | 03:36 PM
erd90vettesc's Avatar
erd90vettesc
I also have a 90 model that used to give me issues starting, especially if the motor was hot. It turned out that the injectors were toast. I replaced them with FIC bosch III and it now starts like a new car no matter the conditions every time. I would also check your fuel pressure as well.
Old Aug 11, 2008 | 03:51 PM
engle1147's Avatar
engle1147
Order some new injectors the stock ones are falty from the factory.... Bosh has a better spray atomization... Check FIC thread for sale info and a great demo of this common type of multec failure.
Good Luck!
Old Aug 11, 2008 | 04:21 PM
mypantera's Avatar
mypantera
What causes the injectors to not spray under some conditions and then spray fine in other conditions?
Old Aug 11, 2008 | 04:26 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
when it comes to the Multec, who knows, they have a mind of their own when the coils are bad. They are erratic at high pressure also.
Old Aug 11, 2008 | 04:40 PM
mypantera's Avatar
mypantera
Thanks FICINJECTORS for your PM and the link on how to check injectors.
I measured all of the injectors with the engine cold. I also put in new bateries in my ohm meter just in case. The car has sat for a long time in between driving....
Cyl 1 = .016
Cyl 2 = .016
Cyl 3 = .016
Cyl 4 = .017
Cyl 5 = .016
Cyl 6 = .016
Cyl 7 = .016
Cyl 8 = .017
Old Aug 11, 2008 | 09:01 PM
FICINJECTORS
Supporting Vendor
Cyl 1 = .016
Cyl 2 = .016
Cyl 3 = .016
Cyl 4 = .017
Cyl 5 = .016
Cyl 6 = .016
Cyl 7 = .016
Cyl 8 = .017
the coils are all in range.. I would look elsewhere. it might not be fuel delivery.
Old Apr 11, 2010 | 06:42 PM
mypantera's Avatar
mypantera
Well here it is a year + later and I am finally getting back to work on the 90. I tried starting it today with no luck at all. It turned over fine with no issues there but just would not start. To me it sounded like I wasn't getting any fuel and/or spark. When I checked the injectors a while back all the coils were in the .016/.017 range. I did not check today as I was by myself but last time it had great spark also. Still sounds like a fuel problem to me??? Any idea where or what I should check next? If you read my first post in this thread you will see how it was acting up prior to being stored.
Thanks!!
Old Apr 13, 2010 | 04:52 PM
CaminoSS's Avatar
CaminoSS
Change the injectors. My 90 had similar issue but my injectors were all bad. Changed the injectors and problem was gone. On top of that I picked up a little better milage. Go ahead and get them from Jon. You will not be sorry.
Old Apr 14, 2010 | 12:06 AM
jfb's Avatar
jfb
Buy a fuel pressure gauge (about $12) and connect it to the shrader valve on the right side fuel rail. Turn the ign on for longer than 2 seconds and turn it off. You should get 35-42 psi and it should hold up for a long time. If you lose pressure rapidly, you likely have one or more injectors that are leaking. Also, while everyone has an ohmeter, ohmeters only make a d.c. (direct current) test of the injector coil and injectors receive pulses from the ECM and a much more sensitive test for injector coils is to measure their a.c. (alternating current) impedance. An ohmeter cannot find a coil with a turn to turn short (the change in resistance is microscopic), and this defect will not allow the injector to work, BUT...an impedance bridge will find this kind of defect instantly!
FIC injectors is in the business of testing and selling injectors and I would recommend that you listen to his advice and take advantage of his experience.
Also, your injector coils should measure around 16 ohms, not .016 ohms.
Old Apr 19, 2010 | 02:07 PM
mypantera's Avatar
mypantera
Update....
It has finally stopped raining so I went out today and tried a bunch of the tips people have given me. I applied 12V power to the "G" terminal on the ALDL and nothing. I checked and replaced the fuse and also switched out the relay with one of the other three that were under the dash and still nothing. When I run 12V directly to the pump the car starts perfectly. I am not even sure where to start chasing the wires in this car are there are a million of them!!
Old Apr 19, 2010 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you have the 90 FSM ?
There are 2 sources of power for fuel pump, the fuel pump relay and an oil pressure switch. The oil pressure switch should apply power to pump at about 4 psi, so cranking should trip the switch. Maybe you have a blown fusible link that feeds the relay and switch, or some bad wiring/connection.
Old Apr 19, 2010 | 08:18 PM
mypantera's Avatar
mypantera
Not sure what 90 FSM means....
I replaced a fuse that was under the passenger dash labeled fuel2 or something like that and I also found a power fuseable link wire coming off some relay or block behind the battery that had been poorly spliced together. I cut out the bad splice and reconnected the wires together and now the car is starting right up. Running a little poorly now but it is possible that i knocked off a wire somewhere... will check for that soon.
Old Apr 19, 2010 | 11:42 PM
jfb's Avatar
jfb
1990 Field Service Manual = 90 FSM
To 90 - starting / no starting problem
