hello and help with info
Old Aug 13, 2008 | 01:39 AM
sidescrollin's Avatar
sidescrollin
2nd Gear
Default hello and help with info
I've been passing the same c4 sitting at the edge of the road for all the years ive been in high school. Its been sitting there quite a while and it looks kinda rough. I'm thinking about checking it out and see what they wanna get rid of it for. Since i havent looked or asked I have no idea what condition its in or even the year. Its faded out gold and the only gold c4s ive seen are 84s so Im assuming its older.
I was looking for some general info on the car, whether or not it would be worth fixing up, performance, common issues. I know they are like most 80s and early 90s cars and some of them cap the speedo at 85. Im going to assume its the lowest perfomance and its a l83. These are rated at 200 or 205 right?? is there a computer cap on the Top speed or will it actually do over 85 and showup on the speedo?? It could be very possibly it went underwater during a hurricane, if so Im not gonna bother because that can cause alot of problems.
~thanks all
Old Aug 13, 2008 | 01:45 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
Be careful on purchases of C4 vettes that need alot of work. Sometimes its cheaper to buy one in decent condition than to take on a task of what you are talking about. Good Luck!!!!
Keep looking if this one is not the right one. I can tell you from 30+ years of owning vettes that they are fun and cool to drive.
Old Aug 13, 2008 | 06:44 AM
rons85's Avatar
rons85
Stock, running "right", the Crossfire L83 1984 'vette was good for about 140 mph. In that ballpark, anyhow. Not a lot of HP there by Todays standards, but it was a monster in 1984.
Yes - the speedometer displays numbers that high - the bar graph display stops at 85 (or whatever), That doesn't change, but the Numeric display (the Numbers) keep on counting up.
Old Aug 13, 2008 | 11:21 AM
sidescrollin
2nd Gear
ok, thanks alot
Also, are there many mods and parts for the l83?different performance heads,intake manifolds,plenums,etc
Old Aug 13, 2008 | 02:28 PM
69mako's Avatar
69mako
Run!!! Run away from that thing.....Vettes in good condition have enough problems and ill temperments on their own....a Vette thats been sitting for awhile with out service....thats just a black hole waiting to suck up some poor kid and his hard earned money
RUN! while you still have a life!!
Old Aug 13, 2008 | 02:33 PM
shamdave's Avatar
shamdave
OMG no truer words! if you are going to take on one that has sat do this! Ditch the FI and put on a carb set up otherwisem you chase sensor gremlins till you die!
I have an 85 and it has to be a woman Cause only a female could treat me this bad,take all my money and i still keep coming back for more!!!
To hello and help with info
