84 Fuel Pressure???
Old Aug 14, 2008 | 07:00 PM
vetteguy0483's Avatar
vetteguy0483
Default 84 Fuel Pressure???
What is the correct fuel pressure for a 84?
For some reason the search isnt working
Old Aug 14, 2008 | 08:08 PM
blackbear bob's Avatar
blackbear bob
9 - 13 psi
Bob
Old Aug 14, 2008 | 08:27 PM
vetteguy0483
holy crap.
really?
ok
thanks
Old Aug 14, 2008 | 09:26 PM
xrcrx's Avatar
xrcrx
Default TPI pump
If your pump is a bit weak, upgrade to a TPI pump. The added pressure will bypass to the tank, while iinsuring no throttle lag do to an initial pressure drop at the injectors when more throttle is demanded. This elimination of the lag from a weak pump is why some folks report a "power increase" with the late model fuel pump.
To 84 Fuel Pressure???
