Dead Battery
Old Aug 16, 2008 | 10:04 PM
Putter's Avatar
Putter
Default Dead Battery
I tried to start my 90 this evening after being on vacation for a week. The battery would not turn the engine over, but I could hear a ticking noise coming from the center of the dash area. I pulled different fuses until the noise quit. The fuse I pulled for the courtesy lights stopped the noise.
I have connected the battery charger to the battery.
I have no idea what is causing the noise. It is a steady ticking (clicking) noise. I would appreciate any suggestions as what to check.
Thank you
Old Aug 16, 2008 | 10:24 PM
MK 82's Avatar
MK 82
These cars can make some strange noises when the voltage is low. It should go away when the battery is charged.
Old Aug 16, 2008 | 10:34 PM
StealthLT4's Avatar
StealthLT4
How old is the battery? When I bought my car, I couldn't even keep the doors open for a couple hours and start the car. After it died completely a couple times I broke down and got a new battery and everything works fine now!
Speaking of which, I accidentally left the door open all night, and it started up perfectly this morning!
Old Aug 16, 2008 | 10:40 PM
Putter's Avatar
Putter
I replaced the battery in January.
Prior to this the car has been running excellent.
I took the charger off and it started. It seems to run good. I will replace the fuse in the morning and keep an eye on it for the next couple of days.
Old Aug 17, 2008 | 12:33 AM
jfb's Avatar
jfb
The ticking you heard was the theft deterrent relay cycling. When the battery voltage drops to a certain level, the theft circuit no longer works properly and causes its relay to click on and off.
Old Aug 17, 2008 | 10:01 AM
Sam Lam's Avatar
Sam Lam
Putter: It is not "normal" for a battery to drain down when left sitting for a week. Did you accidently leave some electrical device on in the car while it was sitting for a week? If not, you have some problem working in the elecrical system and it may haunt you in the future! FYI only.
Old Aug 17, 2008 | 11:55 AM
vette079's Avatar
vette079
Check the little **** in the back of each door (for the interior lights), they can get stuck. You can pull out the little **** in the **** in the door (quarter inch wide, looks like head of a nail), it´s an "adjuster". Use a putty knife to pry it out a little bit. Can be the cause of your problem. I had it once, few weeks later it happened again. Then I found the metal contact inside the **** had corroded and had to buy a new one. Mine was not repairable. 13 USD at Eckler´s. Good luck with what you find.
Sweet 90's Avatar
Sweet 90
Hey Putter, I too have been chasing this exact same gremlin as well in my '90. I finally have taken mine in and should know late next week what the problem is. If you're still having a problem then, I will be glad to share their findings with you.
Jim
Old Aug 17, 2008 | 04:43 PM
Putter's Avatar
Putter
Guess what? After only 7 months, the battery was no good!
I took the battery to the dealer and had it tested - bad. New battery was installed, courtesy light fuse replaced and a 60 mile cruise around the area. No more ticking (clicking) noise and everything works!
Thank you for the input.
Old Aug 17, 2008 | 05:56 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I suggest that you get a Battery Tender. They are only about $50 and they will keep your Vette's battery in great shape. These cars tend to drain batteries within a few weeks of sitting and while you might think that driving around for and hour or so here and there will keep your battery charged, it will not. The Battery Tender WILL keep your battery fully charged at all times. Once you get one, you will not want to do without one again.
http://batterytender.com/product_inf...722d04a0bbd62b
Old Aug 17, 2008 | 09:25 PM
the blur's Avatar
the blur
My battery tender did not work right with the battery still connected to the car. It was showing an 80% plus charge, but the battery was still dead. I disconnected the battery, only then would it take a charge.
and yes, these cars act very weird with a weak battery. clicking sounds, horns beeping lowly. flickering lights. sys messages. weird stuff.....
Old Aug 21, 2010 | 07:52 AM
ehengeve's Avatar
ehengeve
I have the same problem. Purchased a new battery in July 5 weeks later it's dead.
Old Aug 21, 2010 | 09:38 AM
jan-erik's Avatar
jan-erik
Hi.
I have an 85 but this problem smells as the one I had. It is known that the courtesy lamps module sometimes are bad and then they drain the battery and it normally takes 1-2 weeks. Think Corvette Central has those or may be Ecklers. They are dscontinued by GM.
An experiment to see if it is the module is to pull the fuse and let it stand and see if it drains the battery or measure the current drain when everything else are shut off Ignition switch off. Then see if there is a drain and then pull the safety and see if the drain dissappear
To Dead Battery
