Code 41 -- I am nearly bald!
Old Aug 19, 2008 | 06:23 PM
ceberus's Avatar
ceberus
Default Code 41 -- I am nearly bald!
Well I am pulling my hair out. My car still will not crank after replacing the ICM, and the computer is still throwing code 41. Does anyone have experience with this code?
My next guess is that it could be the crankshaft sensor -- but I have no clue where to find it our even how to replace it.
Any advise is appreciated....
Old Aug 19, 2008 | 06:32 PM
blankmantn's Avatar
blankmantn
What year?? 92 and 93 have a different meaning for those codes. Mine is a 93 and I replaced the ECM and that fixed my code 41 in module #9. Hope this helps.
Old Aug 19, 2008 | 06:38 PM
MK 82's Avatar
MK 82
Your car does not have a Crankshaft Position Sensor if that is what you are referring to. And if it did, it would not keep it from starting.
Old Aug 19, 2008 | 06:53 PM
ceberus's Avatar
ceberus
thanks for your replies!
The C4 is a 1992, now I am thinking I got a bad ICM from autozone. I might try and return it, and see if a new one helps.
Old Aug 19, 2008 | 07:35 PM
vetteracer92's Avatar
vetteracer92
code 41--electronic spark timing (open or shorted circuit)
did you check voltage the end white wire on the coil driver(terminal B)? Should be .5 volts with ignition "on". Is more than .5 volts present?
Yes or No answer please(from the red service manual)
Old Aug 19, 2008 | 09:33 PM
ceberus's Avatar
ceberus
Yes, 12V are present -- the same voltage as my car battery.
Old Aug 19, 2008 | 09:47 PM
MikeC4's Avatar
MikeC4
Forgetting about the code41 for a moment:
Did you check your fuel pressure at fuel rail ?
Did you check for spark at any of your plugs ?
Autozone should have equioment to test the ICM they sold you.
Old Aug 19, 2008 | 10:22 PM
vetteracer92
A code 41 will disable the injectors to prevent flooding of the engine.
12 volts is way too much, the est range should be .5 to 4.5. Are you measuring the right wire? there are two of them, one goes to the coil and one to the ecm(which is the one to measure)if so, the next step in line
ignition "off". disconnect ecm connector "A" (yellow or grey color), ignition "on" is voltage present?
if not-faulty ecm. if yes short to voltage in est circuit.
This is coming from the FSM for a 92. hope it all turns out all right for you.
Another thing to check also is the condition of the wiring all around the icm, I've recieved an esc fail code and found the wire to my coolant temp sensor was split. after I replaced the wire everything ran fine.
Old Aug 19, 2008 | 11:41 PM
Lichen's Avatar
Lichen
Code 42 is the ICM. You were chasing the wrong culprit.
Old Aug 21, 2008 | 05:08 PM
ceberus's Avatar
ceberus
Okay, I am following the same troubleshooting chart from the manuals.
Code 41 set ---> Yes
Is Voltage in terminal B > .5? ---> Yes (12V)
Disconnect terminal B from ECM, still voltage? --> Yes (12V)
Result --> Short to Voltage in EST circuit.
I am very certain of the results, but I am not sure how to proceed from here. Anyone have any experience in how to determine the source of of the short in the EST circuit?
Old Aug 21, 2008 | 05:59 PM
toptechx6's Avatar
toptechx6
The wiring diagram in my book shows the wire running directly from the ICM to pin A12 at the ECM, you need to physically trace that wire.
Old Aug 21, 2008 | 07:48 PM
MikeC4's Avatar
MikeC4
You can take the ICM back to autozone and they have equipment to test it.
Old Aug 21, 2008 | 08:26 PM
ceberus's Avatar
ceberus
This is very strange.
The wire from coil driver terminal D is white.
If I trace it through the wiring tubes all the way back to the ECM, it terminates as a blue wire into the ECM bulkhead pin A-12.
Is there possible some type of connector in between that will require to take the tubes apart? I am trying to avoid that because it looks like a full days work.
Old Aug 21, 2008 | 08:31 PM
WW7's Avatar
WW7
for a code #41 Check wiring at ECM. Possible PROM failure, or incorrectly seated PROM. Reseat PROM. Possible ECM failure.
Old Aug 21, 2008 | 08:53 PM
ceberus's Avatar
ceberus
Yeah I have tried all that but now luck. Do you have any info on Code 73. I am getting codes 41 and 73.
Old Aug 22, 2008 | 05:17 AM
toptechx6's Avatar
toptechx6
My wiring diagram shows no connectors in circuit 423 (white wire) between the ICM and ECM, I am using a 93 book.
The only DTC 73 I find is an ABS/ASR code, "Spark Retard Monitoring Malfunction". The circuit in question runs from ECM terminal A22 to the EBTCM behind the drivers seat.
Based on your symptoms and testing so far I would look carefully at the wiring to ECM connector A (gray)
If you have done any work to the car recently make sure something in that area of repair did not pinch the harness, good luck.
Old Aug 22, 2008 | 06:41 AM
Road Agent's Avatar
Road Agent
How can the voltage at terminal B be .5 if your measuring 12.volts
To Code 41 -- I am nearly bald!
Old Aug 22, 2008 | 07:06 AM
MikeC4's Avatar
MikeC4
Check your coil:
There is definately an ICM connection to the ECM/PCM(The ICM must connect and break power to the coil at the right time. You can put a test light across the A and D terminals to test this - spin the engine and see if the light blinks on and off. The "timing" of terminal A and D is regulated by terminal B from the ECM. This "timing" is calculated by things like O2 sensor voltage feedback, TPS voltage, MAF or MAP voltage, etc. )
The EST, or Electronic Spark Timing is the signal that is generated from terminal B of the ECM. This EST signal ultimately controls when the coil fires(sometime before TDC of compression stroke for each cylinder. In this picture, the coil charge is being represented as current charge/discarge so the voltage is generated when the current goes from High(charge) to Low(discharge) state ).
The ECM will "shift" the EST pulse train back and forth as necessary to adjust timing(advance and retard). These are the timing adjustments as calculated by the various sensors. The 720 slots in the high resolution disc inside the Opti represent 1 degree of timing each.
Old Aug 23, 2008 | 07:21 AM
topspin's Avatar
topspin
Ignition Control Module should receive AC voltage at the B pin on the connector on my 96 LT-1. Are you measuring on the AC scale. A and D on mine is 12 volts DC. The C is ground....
Old Aug 23, 2008 | 07:29 AM
topspin's Avatar
topspin
The AC voltage is checked by unplugging the ign con mod conn and checking it with meter on AC scale but remember to have someone cranking engine with key while checking for voltage.
