Stupid Cooling Question
Once again, how long do they run?
P.S I run a stock heavy duty unit in my personal vehicle that we talked about the other day on the phone and it does ok around town (no AC) with a big flex fan pulling air in, but shoots right up in temp when we put some power down. And one more thing, cars like top fuel drag cars and such that don't use gasoline don't have issues with heating up; we run 900 hp sprint cars with relatively teeny radiators, switch them to gas like they did with modified’s years ago and cooling becomes a huge issue. Sorry for the long post. How's the engine coming along?
I think I will intentionally make an incredibly bogus statement as fact so you can jump up and down and salivate on your keyboard.
Not!
The exhaust stroke on your uber efficient motor takes just as long at a given rpm as it does on a GM *** motor. So I fail to see how less heat would soak into the engine in one vs the other, except of course that the GM **** motor didn't have as much heat to begin with since it doesn't breath intake air as efficiently.
Really, though, what's the point here? If it's that you don't want to upgrade your radiator, don't. There's certainly a chance it will be acceptable. And if it's not, you'll notice and fix it.
It never ceases to amaze me the things people will say to another, safe in the anonymity of the interweb, that they would never say to their face.
I never had any intent to swap out the stock radiator until I see the results. I alreday did that listening to people tell me about headers and heated O2 sensors, which turned out to be a bunch of crap....ran fine with stock O2 sensors, and ran with codes on heated ones.
SO....I wasn't asking advice, I was spurring discussions.
Also the less airflow through the radiator the larger the radiator needs to be. NASCARs have lots-o-airflow throw the radiator to help exchange even more heat, same with most racing radiators. The C6R radiator is tiny compared to my stock trucks radiator.
The improved cooling of the dart block is just that it gets more heat from the motor into the water in the appropriate places to prevent hot spots and the like. Once that water is out of the block it has to be released into the atmosphere. So you are going to need a heat exchanger upto the task. This does not answer the question of whether or not your existing radiator is up to the task or not.
Full Disclosure: I have a dewitts aluminum radiator and spal fans on my C3. It sure as heck cools my C3 a lot better than the stock brass one did. And it is around 19x31.
The simple answer is that you are burning more air/fuel with more surface area to absord it, and you even said the block was better for cooling. Which all means there is more heat in the water, and that heat has got to get out of the water.
His input is welcome here but he has to be able to back it up.
MK 82 is correct to point out that the amount of heat energy that is generated is governed by the laws of thermodynamics.
A 427 engine displaces 22% more volume than a 350. For the sake of argument (and simplicity), let's assume that both engines run at exactly the same air fuel ratio, the same volumetric and thermal efficiencies, and have the same combustion characteristics as a bone stock L98. That being the case, the 427 will require 22% more fuel to maintain the same AFR as the 350. The total amount of energy released by the fuel during combustion will then be 22% higher in the 427. Since this example assumes the thermal efficiency of both engines to be the same, a 427 will generate 22% additional waste energy that needs to be dissipated by the cooling system.
This is very simplistic, obviously, and is only based on the difference in displacement. A high performance engine such as what John is building will generate significantly more heat over and above the heat related to the displacement difference due to the power levels he wants to achieve (more power = more airflow in/out = more fuel). It would not surprise me to see the maximum cooling system load increased by 30-40% compared to the L98.
My personal opinion is that the stock cooling system most likely won't be able to cope with the additional heat under high load conditions (hot day idling with the air on, extended full throttle blasts, etc), but I think you could leave it stock for the time being and monitor it closely while you get the tune dialed in to see how much cooling margin (or lack thereof) you really have.
The bottom line is that about 1/3 of the energy from combustion goes into heat. GM sized the Corvette's cooling system for a certain amount of heat rejection. If you make 50% more power than GM designed for (so 50% more heat), you need to increase your cooling system's heat rejection capability by 50%.
Remember, GM may have designed a 50% safety factor into the cooling system...so you could be running on the ragged edge of safety for this assumption. You do not have to install a higher capacity radiator, however, to attain this (though this is the easiest way). For a few hundred bucks it is definety worth it. People can talk all day about how they ran this setup and that setup successfully, and there is no questioning that...but I'm not the kind of person to look at an 80 year old person that's smoked all their life without having cancer and think that this is the benchmark for a healthy lifestyle. It should be fairly easy to ballpark what GM sized the cooling system for, as the thermodynamic equations for cooling fins are well known and some air speeds, humidity, and temperatures can be assumed. If you're curious shoot me a PM and I'll dig out some of my old books when I get a chance.
