help me!
Old Aug 26, 2008 | 08:02 PM
dmukina's Avatar
dmukina
Default help me!
So i purchased the 52 mm bbk tb for my 1992 lt1. My lt1 Does not have the Air intake manifold with the runners, mine is similar to the lt4, so when i went to install my bbk tb my power coupler was too small and i could not stretch it over the lip on the bbk because the rubber was already ripping. I then purchased the power coupler from ecklers (expensive piece of $90 rubber) and when it came it was to long! It was ment for the air intake manifold that is set up with the runners! so i need to find a new replacement for mine, (pic one). or someone help me with some ideas! PLEASE
Old Aug 26, 2008 | 08:13 PM
engle1147's Avatar
engle1147
Can't you just trim some length off the new one you bought?
You can put your old one in the oven for @ 300 degrees until it gets plyable and stretch it out as you put it on the TB.
Old Aug 26, 2008 | 09:47 PM
Lichen's Avatar
Lichen
You're original coupler will fit. Just get it really warm (just not enough to melt it) and it will stretch enough to fit. I had this problem at first, but now it fits perfectly.
Old Aug 26, 2008 | 10:37 PM
dmukina's Avatar
dmukina
I CAN'T use the old one because its RIPPING around the lip that slides on the tb!
looking for replacement or some other ideas.
Old Aug 27, 2008 | 02:21 PM
dmukina's Avatar
dmukina
anyone else?
Old Aug 27, 2008 | 06:00 PM
Razor89's Avatar
Razor89
How about stretching it like I did.
Took my time and moved the coupler a little at a time.
Old Aug 27, 2008 | 06:52 PM
Kool88vette's Avatar
Kool88vette
I had the same problem. The 52 mm BBK lip is a little bigger that the stock TB. Someone here told me to heat up the air bridge. I tried that but it did not work.
I did get it on. I disconnected the air bridge from the air box. I placed it 3/4 of the way on the BBK without the metal strap. I put a shoehorn inside the air bridge and slipped it on. Then I took the strap apart and installed it. I guess you could just loosen the strap up.
Old Aug 27, 2008 | 06:57 PM
Kool88vette
Also, I would send that rubber thing back to eckler's. It will dry out and decay from the heat of your engine. You could suck a piece of rubber into your engine and POW! Get an OEM replacement. One from salvage yard is better than that one from Eckler's.
Corvette central sells the same part for $45.00.
Old Aug 27, 2008 | 11:14 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
More than one member has fabbed their own from a traffic cone.
To help me!
