Please help
Old Aug 27, 2008 | 07:29 AM
CHAMPVETTE_86's Avatar
CHAMPVETTE_86
Cruising
Default Please help
hey guys....joined up awhile back and then have been really busy with fixong up the house and trying to get the vette running right...
so i changed out the upper intake tubes and intake....put a polished throttle body on and put a new fuel pressure regulator on...now the cars runs like crap....
ive adjusted the fuel pressure to what the chilton book for it suggests and adjusted the throttle body sensor to the correct position. Still runs crappy...backfiring and no power when the gas is applied...
Im out of ideas....
CHAMPVETTE_86
Cruising
everything is back on the car...all vacuum lines and hoses
Old Aug 27, 2008 | 08:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Was the distributor removed for the work done ?? Are you sure there are no vacuum leaks ?? Was the MAT sensor put into plenum ??
Old Aug 27, 2008 | 07:12 PM
CHAMPVETTE_86
Cruising
didnt remove the distributor, no leaks...had one and fixed...., and the MAt sensor is in
Old Aug 27, 2008 | 11:12 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
If it's back firing it has to be firing when the intake valve is open.
Somewhere, somehow it sounds like your timing is out of wack.
Old Aug 28, 2008 | 08:53 AM
rons85's Avatar
rons85
Actually, if it's "backfiring" or "popping" in the intake there is most likely a vacuum leak Someplace. Look hard enough and you'll find it.. (easy for Me to say...)
To Please help
