Emergency! Help needed fast!
Old Aug 29, 2008 | 04:02 PM
Benny42's Avatar
Benny42
Sorry about that. I realized i was on the wrong side of the car and
may have messed you up. I hope you get it done. benny
Old Aug 29, 2008 | 04:10 PM
cwyates4's Avatar
cwyates4
Ok, connected tan to a black (not sure which, shouldn't matter) and jumped pink and blue, and all I got was sparks and smoke again. Then I accidently hit the window switch downward with tan and ground still connected and made more smoke and one hot paperclip.
Where'd I go wrong?
do the wires have to be removed from the switch assembly to do this? shouldn't be...
Old Aug 29, 2008 | 04:12 PM
Benny42's Avatar
Benny42
Wires MUST be removed from switch. It will short to ground if you don't.
benny
Old Aug 29, 2008 | 04:13 PM
MK 82's Avatar
MK 82
Here is how to do it on a 96.
Remove switch from socket
Terminal G Yellow--should show 12 V with switch on.
Terminal D Dark Blue
Terminal C Brown
Terminal F Black
Jump G to C
Jump D to F
Window should go up.
Old Aug 29, 2008 | 04:14 PM
cwyates4's Avatar
cwyates4
wait a sec...couldn't I just jump off pink twice? run one wire from pink to light blue and the other from pink to ground...that should work right?
Old Aug 29, 2008 | 04:18 PM
Benny42's Avatar
Benny42
No. Pink is +12 to circuit breaker. Black(both) are -12. Blue is motor
and needs +12 for up. Tan is motor and needs -12 for up. benny
Old Aug 29, 2008 | 04:22 PM
MK 82's Avatar
MK 82
What year is the car? If someone can post the schematic we can figure it out. It is a reversible motor.
Old Aug 29, 2008 | 04:25 PM
cwyates4's Avatar
cwyates4
http://members.shaw.ca/agent86/Power...Electrical.pdf
I'm just lost, .
tried the pink to ground and pink to light blue...managed to melt some plastic that time.
MK, see if you can't relate that schematic to a 96's.
Old Aug 29, 2008 | 04:26 PM
cwyates4's Avatar
cwyates4
benny, I tried that and got spark and smoke as soon as I touched pink...already had the other connections established. something ain't addin up.
Old Aug 29, 2008 | 04:27 PM
MK 82's Avatar
MK 82
Pink to Dark Blue
Brown to Black
Just saw Agent 86's input.
Old Aug 29, 2008 | 04:30 PM
Benny42's Avatar
Benny42
The switch MUST be unplugged. It will arc and smoke if its not.
benny
Old Aug 29, 2008 | 04:31 PM
cwyates4's Avatar
cwyates4
well...thats pink to lite blue and black to tan on the pass. side. That didn't work, all I got was spark and smoke.
benny, how do you remove the wires from the switch, I can't see a way to do that without removing the wires one at a time.
  #33
MK 82's Avatar
MK 82
Originally Posted by cwyates4
Hey, you cheated!
I just saw this is for right side.
Pink to Lt Blu
Tan to Black
Old Aug 29, 2008 | 04:33 PM
  #34
MK 82's Avatar
MK 82
You should be able to carefully pry the switch off of the socket.
Doesnt matter if you break the switch.
Old Aug 29, 2008 | 04:38 PM
  #35
cwyates4's Avatar
cwyates4
true, I don't see any other way it could work.
Old Aug 29, 2008 | 04:39 PM
  #36
Benny42's Avatar
Benny42
The plug will slide off of the pins on the switch. It takes a little
prying to get it moving. I think the plug is white, or was. That
is where it separates. A plastic tool is best. benny
Old Aug 29, 2008 | 04:49 PM
  #37
cwyates4's Avatar
cwyates4
oh, well removing the switch was easy.
Window is up! easy once the switch was gone!
Thanks for all the help, and very quick help at that! You guys are great! Now I'll button the dash back up and order a new switch. Might carry the wire and paperclip (already carry that ) so I can roll it down and up as I please.
On a side note, the window motor in that side is and has been slow for 2 years now. Where is the best place to get one? Hard installation?
To Emergency! Help needed fast!
Old Aug 29, 2008 | 05:02 PM
  #38
Benny42's Avatar
Benny42
A little bit of white grease on the tape track and guide post
freed mine up until i scored new style regulators. Where are
you evacuating to? benny
Old Aug 29, 2008 | 07:08 PM
  #39
cwyates4's Avatar
cwyates4
gee, I was plannin' dallas. I've got some family up there, but its quite a drive. College station would be another option. I could stay here in Jasper too.
whatever I do, I won't be staying at school in beaumont, thats for sure!
Old Aug 30, 2008 | 10:49 AM
  #40
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sorry I missed all the excitement !!
