Cranking Problem
Old Jan 4, 2002 | 03:58 PM
MostWanted's Avatar
MostWanted
Default Cranking Problem
When I try to start her first thing in the morning, she fires right up. If I drive somewhere and turn her off, she takes forever to crank (constantly turning over but doesn't start) It cranks no problem when I let her sit for a good while. Does this sound like the distributor? Thanks!
Old Jan 4, 2002 | 04:10 PM
jfb's Avatar
jfb
Default Re: Cranking Problem (TorchRedXCVI)
Sounds like leaky injectors. Connect a fuel pressure gauge on the shrader valve at the end of the fuel rail, turn on the ignition until fuel pressure comes up and shut the ignition off. A loss of more than 1 psi in 30 minutes is considered excessive by GM.
