Just Ordered an X-RAM
Old Jan 5, 2002 | 11:06 AM
IceDigger's Avatar
IceDigger
Default Just Ordered an X-RAM
Via cod since I have no clue when I will actually get it.
But when/if I do.... :)
Should be fun once it arrives (hopefully before the spring)
Anybody else here have an X-RAM installed in thier 84?
Old Jan 5, 2002 | 12:14 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: Just Ordered an X-RAM
I dont, i am gonna port instead. From what i hear, you wont sorry with the X-ram. :chevy
Old Jan 5, 2002 | 12:58 PM
cecil-1's Avatar
cecil-1
Default Re: Just Ordered an X-RAM (GiDvEtTe84)
I wanted to get one this winter.
But my tranny crapped on me in Nov. :(
Haven't decided if I am going to get this one rebuilt
or get a new one.
[Modified by cecil-1, 11:59 AM 1/5/2002]
Old Jan 5, 2002 | 01:31 PM
john25's Avatar
john25
Default Re: Just Ordered an X-RAM (cecil-1)
Cecil-1, I just want to compliment you on a very nice '84.
Old Jan 5, 2002 | 06:52 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Just Ordered an X-RAM (IceDigger)
A few of MY feelings about the X-Ram. All the reports I have seen, state tremendous power gains. Almost too much in some reports, but I believe they must be an excellent power enhancement. If your goal is to maintain the "stock" crossfire LOOK and add power, it is a good way to go. Realize that although you keep your stock air cleaner, you no longer have a crossfire engine. SOME people are crossfire purists. If you don't care about having a "crossfire" I think that there are more powerful alternatives available. But probably not as inexpensive. You pays your money, and you takes your choice. These are just a couple of MY thoughts on the X-Ram. Have fun.
Old Jan 5, 2002 | 07:25 PM
Nitro Junkie's Avatar
Nitro Junkie
Was thinking about X-ram,but think I will go with this instead:
Old Jan 6, 2002 | 02:22 AM
john25's Avatar
john25
Default Re: Just Ordered an X-RAM (Nitro Junkie)
I thought about using the Offenhauser crossram but the stock HEI distributor can't be used. It's stated in the footnotes for the crossram. I don't think the F body small cap distributor is a direct plug in for use in a Vette. What are your plans for a distributor? I may reconsider using this if you have a solution.
Old Jan 6, 2002 | 02:36 AM
Nitro Junkie
Default Re: Just Ordered an X-RAM (john25)
I haven't heard that one. I checked on the crossfireforum, and that issue never came up. I will double check.
Old Jan 6, 2002 | 06:43 AM
Twin_Turbo's Avatar
Twin_Turbo
Tha vac. advance one probably doesn't fit. 82 & 84 Hei distr. fits just fine.
Marck
Old Jan 6, 2002 | 09:57 AM
Lionsden's Avatar
Lionsden
The Offy Crossram will work with the HEI if throttle bodies are used. The clearance problem must be when using carburetors. The HEI vacuum advance is on the passenger side. From visualizing with pictures it doesn't look like the Vacuum advance would have a clearance problem
[Modified by Dan Plett, 8:04 AM 1/6/2002]
Old Jan 6, 2002 | 07:32 PM
john25's Avatar
john25
Default Re: Just Ordered an X-RAM (Dan Plett)
Is that picture of the Crossram installed in an '84 your Vette? I sure would like to see more pics of the install from all sides if possible. If you have any other information on this installation I'd be very interested.
Old Jan 6, 2002 | 11:26 PM
GiDvEtTe84's Avatar
GiDvEtTe84
No, thats not his. Its a guy whos sceen name is Pokey at the crossfire forum. He had it running but his lower end went out afterwards. Thinking about switching over to wet flow? :crazy:
Old Jan 7, 2002 | 02:21 PM
JoBy's Avatar
JoBy
These are the three pictures I have of Pokey's installation.
(Click to enlarge)
[Modified by JoBy, 7:22 PM 1/7/2002]
To Just Ordered an X-RAM
